The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
I'd check junk yards, though that may be a crap shoot, or look into an aftermarket setup.my back up camera is blue !!!!…..they want $800.00 for new one
Pixelation occurs with a weak signal. If you can find the connections I'd check for corrosion starting at the camera since it the most exposed.
I don't know for sure, but a few years back the one on my Sonata died. They just replaced the camera and nothing else.do you think I'm wasting my time buying new camera assembly for $267 or do you think it goes deeper than blue screen problem....?
I just replaced my camera due to the same issue you having, every once and a while it would act up then one day it just stopped working. I got a OEM camera off of ebay ...had to remove the backup lights and lower trunk outer shell to get to the camera ...as I said in my post after replacing it ...didn't realize how much I used it until it didn't workI disassemble everything and cleaned camera , connections and everything , still have blue screen , 2014 rspec
Thank youI don't know for sure, but a few years back the one on my Sonata died. They just replaced the camera and nothing else.
Did the new one work ?I just replaced my camera due to the same issue you having, every once and a while it would act up then one day it just stopped working. I got a OEM camera off of ebay ...had to remove the backup lights and lower trunk outer shell to get to the camera ...as I said in my post after replacing it ...didn't realize how much I used it until it didn't work
Yes Sir! Before I removed the lights and trunk shell, I removed the trunk lining and connected it ...Wala rear view was backDid the new one work ?
