Back up camera question
my back up camera is blue !!!!…..they want $800.00 for new one
yes sir , just started looking for new , found them starting at $247 to $400 for assembly. thank you
Pixelation occurs with a weak signal. If you can find the connections I'd check for corrosion starting at the camera since it the most exposed.
do you think I'm wasting my time buying new camera assembly for $267 or do you think it goes deeper than blue screen problem....?
I don't know for sure, but a few years back the one on my Sonata died. They just replaced the camera and nothing else.
I disassemble everything and cleaned camera , connections and everything , still have blue screen , 2014 rspec
I just replaced my camera due to the same issue you having, every once and a while it would act up then one day it just stopped working. I got a OEM camera off of ebay ...had to remove the backup lights and lower trunk outer shell to get to the camera ...as I said in my post after replacing it ...didn't realize how much I used it until it didn't work
Thank you
Thank you
Did the new one work ?
