Transmission issue
I've felt a hard downshift more than a couple of times. It's more evident when coasting and I have to apply the brakes. Sometimes is on the contrary, when coasting at highway speeds and I suddenly need to apply the gas pedal the tranny jerks when upshifts. It's as if the tranny doesn't engage the correct speed for the actual RPM.
Right, but if some people are saying they’ve never felt this... I wonder if it’s a difference of feeling or an actual difference
Other than maybe a thermostat, can’t imagine anything being internal to the transmission cooler? If over temp related, seems the ECU would pick up on that and throw an engine code? Under normal driving can’t figure the transmission getting all that hot? I read somewhere our engines have an electronic thermostat fully controlled by the ECU and not a conventional one that is heat controlled with no computer. Not sure if the transmission cooler lines and the engine coolant hoses all see the same temps and are tied together, or independently controlled somehow?
Afyer some research on the interweb, it seems as though the internal core is cracking at the seams of the tubes inside the cooler allowing the coolant and oil to mix creating a sludge that eventually clogs things up within the transmission and even the engine internals where the shared coolant passes through the jackets. It makes a real mess apparently.
This is very subjective, the only way to get the real answer is to have the same car being driven by two different drivers or vice versa, two different cars driven by just one driver.
You’ve never had it hard shift during a downshift? A feeling like it didn’t quite match rpms to be smooth and it results in a jerk as you’re braking or coasting down?
Nope. Despite the subjectivity of this, I really feel like my tranny has always downshifted very smoothly and calmly. I've not once felt it jerk, or shift hard, not at all.
Is this a water cooled transmission oil cooler? All the oil coolers I've seen were air cooled, like a normal radiator.
Not good at all. I have not poked around under the hood yet to see if we have a transmission dip stick or not? If a contamination gets in the transmission fluid if would show up on the dip stick. A external tranny cooler would have mitigated co-mingling of fluids vs borrowing from the engine radiator. Newer cars these days seem to not have ways to even re-fill tranny fluid for manufacturers don’t won’t us touching the tranny.
This is our transmission cooler.
I was under the impression that only ATF flows through there. *shrug*
EDIT: Here's straight from the FSM.... Notice at the very bottom it states to refill with ATF.
Dec '18 build bought Sport Edition 3.3(awd) in July 2019, 3500k - certainly can feel the downshifts but wouldn't say they are jerky, but are noticeable. Aware of it more when driving in ECO mode vs. SPORT or COMFORT.
The engine oil cooler, on the other hand, is a water-to-oil separator. It's that block that the oil filter attaches to. It is object A in the bottom picture of this page from the FSM...
It is the metal portion that the oil filter housing attaches to. This is where oil and coolant equalize temperature relative to each other. These types of coolers can definitely fail, at least in older cars I've worked on. But if this thing is failing I doubt you'd have shifting problems...
Have a little over 3k miles on my 3.3T. Two days ago while coming up to a stop sign in my neighborhood, I let it coast slowly and wasn't going to use the brakes until I needed to. I couldn't tell if it was 3rd to 2nd or 2nd to 1st gear but it was a real hard downshift that jerked me forward pretty good. I then proceeded to drive around the block and tried to duplicate it, it did it once more. I drove around the block and tried several more times after that and it didn't happen anymore. First time this has ever happened since buying the car in July 2019. Also, I did have it in Sport mode. 🤷‍♂️
*Dec 2018 build date
To Elsi point, this is what I'm curious about. What mode are you guys in? I'm currently exclusivley running sport mode during the engine break in and using my paddle shifters quite a bit and the tranny has been fine. I only have a little over 500kms on it though (only have had the car for less than two weeks so not much driving).
Would be interesting to hear what modes are causing this, and if custom mode than what are the settings.
3.3T Prestige, Smart mode almost all the time.
Sport 90% of the time, comfort the rest for me
Just got back from the dealer and had them look at my transmission just in case. They test drove it for 3 miles, and to them it felt fine. They inspected the car and pulled codes from the transmission....nothing. Its documented now, but to my dealer at least everything was fine. It feels good to have some piece of mind, do I still do feel its a little rough. My 2020 3.3 loaner they gave me was buttery on downshifts in all modes, I could feel a difference right away
Nothing a dealer says gives me piece of mind. Many of them are slimy, incompetent idiots who hate the Genesis cars.
I had a clearly noticeable and audible wobble at 60+ mph. I knew for a fact that at least one wheel was out of balance or bent. Took it to three dealerships until the last one agreed there was an issue and ended up finding two wheels out of balance. The first two said it drove perfectly and I was imagining things.
My transmission from day one with 10 miles on the car shifted and still shifts hard especially on downshifts.
I've only tried it a handful of times but for short duration. What is your experience?
I tend towards sport mode the most -- maybe 70% and then eco and comfort depending on the roads. In anything but Winter, Eco is great for short shifting under heavier throttle but not good in winter with all the nannies. Comfort is good because the AWD starts in 50/50, which is good for just general driving. Sport is great all year long, including Winter. The programming and lack of nannies is fun in all seasons.
So it seems I'm having the same issue at 700(!) miles. When car is cold, for example sitting overnight, when coming to first complete stop the car lurches forward and downshift hard into 1st.
Anyone else who has the 3.3 experiencing this?
Me
I don't have winter here in South Florida and my car is RWD. Smart mode is good because the car "react" to the way you drive. If you are in slow traffic or if you want to drive calm without hard accelerations it will behave as if you were on Eco or Comfort mode, but if you get spirited and start pressing the gas the car starts accelerating, changing gears and programming is just like in Sport mode. Resume, is like having all driving modes in just one.
I have a 2020 3.3 sport. Still in break in period. I’ve felt a medium hard down shift a few times while in sport mode only. Nothing that consistent though. Stay in default comfort mode mostly for I have a drive App that spies on my ass. I disable it at times so I can have fun. While in sport mode I’m bad about going 50 in a 30 and not realizing it. Throttle sensitivity can get me in trouble easily. Comfort mode more forgiving on what my foot is doing.
My 2019 3.3 sport is at dealer for the same issue. When coasting under 20 mph it chokes, feels like is hard breaking. Let go off the gas when driving under 20 mph all the way till it stop. I noticed it does it more on eco mode.
My 2019 3.3 sport is at dealer for the same issue. When coasting under 20 mph it chokes, feel like a hard breaking. Let go of the gas when you driving under 20 mph. I noticed it does it more on eco mode.
Let us know what they end up doing to fix it!
