If you click on the file before you connect to the JB4 then it downloads it to the iPhone then once connected to the JB4 hit update the the green arrow on the upper right corner and choose the hex file from there.I’m not the most tech savvy but I’ll give it a try
Thank you for the help. That worked like a charm this morningIf you click on the file before you connect to the JB4 then it downloads it to the iPhone then once connected to the JB4 hit update the the green arrow on the upper right corner and choose the hex file from there.
Dang really? I only have it happen when I don’t input values to hold boost.I set mine to 4 in first and 2 in second and pretty much smoked the tires 1st 2nd & 3rd. Never had that happen before
Interesting. I guess just give it full power since you can manage to keep traction with it lol. I’m still on stock wheels and tires myself idk if you are or notyep. I was rolling to a stop and was almost stopped and engaging launch control and the front tires starting to roll like a true power brake and then the rear lit up and off the brake and 1,2,3 just smoking em.
All stock JB4 of corse & 19’s RWDInteresting. I guess just give it full power since you can manage to keep traction with it lol. I’m still on stock wheels and tires myself idk if you are or not
I have no idea how you can keep tracking then on map 3 lol. I’m always spinning when I launch on 3All stock JB4 of corse & 19’s RWD
Ya please let me know if you figure anything out. I just got my draggy and can’t seem to best a 4.8 0-60 but finally got the car under 13. I’ve been trying to mess with these settings a lot to see what I can come up with as far as traction but I have a feeling my altitude and the fact my tires are pretty much toast now are my down fall at this point.I was only on map 2 Before I had both first and second set to zero and it will just normally launch very little wheel spin just hooks up and goes I’ll keep playing with it see what I can do
I’ve been running 4.45 0-60 and 12.56 1/4 mile and that’s on map 3 and no boost reduction and very little wheel spin.Ya please let me know if you figure anything out. I just got my draggy and can’t seem to best a 4.8 0-60 but finally got the car under 13. I’ve been trying to mess with these settings a lot to see what I can come up with as far as traction but I have a feeling my altitude and the fact my tires are pretty much toast now are my down fall at this point.
I wish I could get that lucky. I can’t find where the draggy says what my DA is. It shows my altitude at 2200 feet but can’t find the other oneI’ve been running 4.45 0-60 and 12.56 1/4 mile and that’s on map 3 and no boost reduction and very little wheel spin.
Trying to get the 1-2 shift at 5500-5600 and the 2-3 at 6100ish I have actually gotten a quicker 0-60 by .1 just leaving it in auto instead of manualWhat shift points are you using?
Does I’d say downloading satellite onto to Draggy? If you skip that step it wont show the DA.I wish I could get that lucky. I can’t find where the draggy says what my DA is. It shows my altitude at 2200 feet but can’t find the other one
Yes it does and I let it loadDoes I’d say downloading satellite onto to Draggy? If you skip that step it wont show the DA.
Hmmm. Where are you located? Doubt it has anything to do with the satellites. May have to contact dragy.Yes it does and I let it load
