2016 3.8 passenger DRL led not working
Jaspiegl727
I am trying to troubleshoot why one of my daytime running light will not work. The lights function properly otherwise. The led does work when the headlights are on but when they are set to AUTO and the DRL's come on and the headlights go off only the driver side works. The passenger side light goes completely off. I have located 3 connections that go into the headlight and all seem to be connected properly. I have checked the manual and do not see a fuse for the running lights. Any help to troubleshoot this is appreciated!!20191026_231503.webp20191026_231442.webp
If you're getting inconsistent output, you probably have an issue with a module.
OMG I have this EXACT issue. Same side and everything on my 2016. Did you find a solution?
Yes....Bad headlight. Whole assembly was replaced under warranty at no cost by dealership.
You're welcome!! If you're still under warranty you should have no problem.
My headlight was replaced due to a fender bender under my insurance. Would warranty still cover this if I take it to the dealer?
