Found a tuning company for 5.0 Sedan's.
jrawk what nitrous kit did you use. your not located near south east pa by any chance do you.
I used the Zex Safe Shot kit and then bought other jets for it so I could run higher than a 35 shot. It's a dry nitrous set up and the reaso I went that route is because I didn't want to mess around with any fuel lines in the car for the wet set up. To answer your other question no I'm in Portland,OR
ok cool. Oregon is a little far for a meet up lol. so what shot are you running.
Yeah it's a slight jaunt to where you are. Lol. But right now I'm running a .083 jet in the nozzle which equals about 75 to 80 hp. The jet kit I bought came with jets all the way up to .125 which is 125hp. So I'm probably going to go up one more jet size and call it good. It's alof of fun. I have to really tell myself that the button isn't there otherwise I would be pressing it all thd time. Lol
Pls make sure you do a dyno to check air ratios when you go to 125s. May be a little too lean at top end with stock fuel system. Better be safe than $$$$$$. Would live to see what that 4.6 puts out @ rear wheels with your boost?
Reason is I don’t think anyone on board has ever shown air ratios for 4.6, may be really different than 5.0.( leaner?).
I also have the ECU and TCU tune now on my car... Is it worth it??? Hell yes lol I'm also running a 4.18 diff out of the coupe. I love the gear usage
2012 Hyundai Genesis 5.0 R-Spec all out acceleration!!!
Hell yeah! I was pissed when I hit 145 and babysitter kicked in. Which tune are you using?
I think he's running the 10Fintec tune. Im running the Alpha-speed ECU tune in my 5.0
Thank you Steve2020 I take that as a compliment. What I can tell everyone on here about nitrous and our cars is, if you have fun driving it now and I mean DRIVING it then you have got to experience the feel when you hit that button. Don't get me wrong, it's not a snap your head back and go into tunnel vision feel like Fast and Furious but it plants you back into your seat quite impressively. Like I had said in my previous posts I have mine set up by button instead of the gas pedal on WOT. A lot of people say nitrous will blow your motor and blah blah which is true it can, but, if you use it like it's meant to be used then there really aren't any unsuspected surprises. When I engage mine it's always over 2500 RPMs, always on wide open throttle and most importantly I never hold the button down for more than like 5 to 10 seconds. As far as the rear end and the tranny I personally have not had any problems at all. If anyone is interested in doing a nitrous set up on their cars I would be happy to answer any questions you might have to the best of my ability
Thanks for the info. I am currently installing a NOS system on my 12 R-Spec. Mine is a wet kit, and I am not sure about where to tap into the fuel system? Is your system wet or dry? Any info you can share would be apperciated.
Anywhere before the high pressure fuel pumps.. so pretty much anywhere on the low-pressure fuel lines coming from the tank up to just before the high pressure pumps
Be careful with your kit regulator selection, IIRC the low side on the DH fuel system can run as high as 190psi before it hits the high pressure pumps that boost it to 2500+ psi.
Tuning gives more gains to turbo motors than to ours. Only about 10 or 15 HP expected, little bit more in the torque. I debated and debated, then decided the car is fine as it is. The biggest gains from tuning our cars would be higher redline, true sport shifting (can bounce off redline if want to) and removing speed limiter.
I'm fine with the car changing at 6,000 rpm in sport mode. Removing the speed limiter makes the car go faster than the tires are rated for. I'm enjoying the car as it is, have not run into a situation where I wished I had more power. 429HP is fine by me.
How do you get your 2012 r-spec into sport mode.
I've since run 12.3 60-130mph. Before I was stuck in the high 13s and sometimes 14s due to crappy DA and stock tune. I've found the sweet spot to shift with the tuned TCU. As soon as the needle touches 7k rpm shift up. Anything after is pretty much a waste and sometimes you'd bounce off of the Rev limiter due to how slow it shifts. I've been data logging quite a bit since the tune and have found when cold the shifts are happening at .120ms-.200ms when hot it creeps all the way up to .600-700ms to shift. Next upgrades will be an upgraded valve body and transcooler for sure. On cold starts with the manual shift mode it is the perfect trans. I mean you bump up and it's almost DCT how fast it shifts I love it! Then it warms up and reality sets in 😔. I will try to go to the drag strip this week and get some official times. My best so far was 13.08@ 109mph and a 60' of 2.08
Where would you get a valve body upgrade at. There is a transmission shop in New Jersey said they could reprogram the transmission but I would have take my car there but I can't remember the company's name.
Not sure if they've gotten better but I remember them having really bad feedback years ago.
Went into the Level 10 Transmission site and saw www.mrflash.com as an apparent official sub company site of Level 10. When on line to a You Tube review of the Thorton Performance OBDII Chip that apparently mrflash uses, full comprehensive test report from Performance Chip Guide- JUNK product! Also showed other exactly same tuners under other names that were also junk. Would advise not waste your money. In fact now see that mrflash name available for sale. Typical ending once individuals understand the items are junk. Change and call it by another name. Can't speak about Level 10 except they advertise mrFlash on their web site.;
If the tune is for the 2015 5.0 engine, can you provide so information on it and a link to a website please.
Have you looked at a (custom) piggyback tune at all? Doesn’t require any ecu input. Not sure if it would get what we want, but it’s better than nothing.
Gelashvilli performance tune. Thank me later. Geptuned.com I'm running his e85 tune and the car has trapped 116mph in the quarter mile. 0-60 is almost 3 seconds
Generally piggy back tunes are not really "custom" tunes. The piggy back tuners usually just "play" with engine sensor data to trick the ECU into running leaner(on N/A engines) or to just increase "boost" on force induction engines.
The problem is that using those methods can just cause damage to the engine and transmission over time since they bypass the engine/transmission factory safe guards.
Most OEM engines and transmissions are not built to make much more power over the stock setup and generally fail by or shortly after 100k miles when tuned without any upgrades. Hence why most tuned stock cars are sold by 100k miles or soon after. The issue can be even worst with a "custom" piggyback tuner spliced into the sensor wires messing up engine data.
Sorry to revive an old thread ! Any new news for the 2020 5.0 Tune ?
