Jtc527
- Sep 12, 2020
- Genesis Model Year
- 2018
- Genesis G80 Sport
I’m in central Florida.
Gainesville fl
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Protect your vehicle from hackers
Genesis parts & accessories
Advertise with us!
Advertise with us!
Gainesville fl
New drive shaft and making sure driveline angle is within spec will fix noise and vibration.Same problem flapping noise 2015 3.8 AWD
i don't have vibration just a noise I afraid of getting one if we replace the shaftNew drive shaft and making sure driveline angle is within spec will fix noise and vibration.
Did this replacement work?Hey guys I posted on another thread yesterday that my dealer located the problem. Replacing the entire driveshaft assembly(which includes the propeller shaft). Used electronic device to locate origin of noise. Noise coming from propeller shaft unit. This unit is directly located underneath the console. That's why when you open up the console the fluttering/clicking noise is more pronounced. Scheduled to install driveshaft assembly this Monday. Will keep ya posted.
Genesis repurchased my car and many others for this unresolved problemIt is a problem that has no permanent fix. Nothing to do with the tires. Just live with the flutter, or if you’ve had the driveshaft assy replaced, the vibration. I try to avoid driving at 28 mph for the first 10 minutes or so, then it goes away. Otherwise the car is great so I’ve learned to live with it.
Genesis makes you file a complaint with the Better Business Bureau first before filing a lemon law complaint. BBB auto Handled the complaints for me completely. Genesis than I have they have a problem and really other than time the process was smoother. Genesis customer care and tell you how to get started and get you a case reference numberWhat was the process for that? I've had the flutter since i purchased the car CPO, and never made a stink as there was never a permanent solution for it. If a repurchase is an option, I'd like to know how to go about it.
