Bswag
SUPPORTING MEMBER
- Jan 10, 2022
- Location
- Charleston SC
- Genesis Model Year
- 2022
- Genesis GV80
Anything you do that modifies the engine boost and parameters will void your warranty. Hopefully none of us do have an issue, but if anyone thinks for one second the factory won't be able to tell the engine was "told" to make more boost and "add" more fuel they are up in the night. You have to pay to play. JMOMotor in gv70 3.5t is the same as the gv80 3.5t.
But the stock plugs can NOT handle the additional heat from the extra boost In Maps 2 & 3. But trying to find the correct colder plugs
To replace the OE plugs is harder than I thought. Especially if changing them could possibly void my 100,000 warranty.
I tried.... Still waiting for a reply from NGK. When you go to there site and search by vehicle .... NOTHING Listed for 2021 Gen GV80View attachment 42700Hope this is something that might help.
They know 100%. In fact due to my misfiring i popped some codes that were automatically sent to Genesis. I recvd emails.Anything you do that modifies the engine boost and parameters will void your warranty. Hopefully none of us do have an issue, but if anyone thinks for one second the factory won't be able to tell the engine was "told" to make more boost and "add" more fuel they are up in the night. You have to pay to play. JMO
OK. The new NGK plugs did the trick! Left the Gap @ .028 NO misfiring or Sputtering in any map. Smooth & Responsive. Ran some logs in Map 0(Stock) & Map 3.
Max boost stock I Hit 10.2 & Max boost Map 3, I hit 15.6. I'm running 93. On to the next mod....
What happened with your warranty? Did genesis void your warranty after they emailed you?They know 100%. In fact due to my misfiring i popped some codes that were automatically sent to Genesis. I recvd emails.
No No.... It was just an automated email through genesis connect... saying had check engine light. That was when it was misfiring.What happened with your warranty? Did genesis void your warranty after they emailed you?
Um…what are you talking about? Supercharger kit??I think that 50 additional HPs aren't enough to make to real improvement, I hope we can one day buy a supercharger kit... just wishful thinking, don't quote me...
are you sniffing glue?I think that 50 additional HPs aren't enough to make to real improvement, I hope we can one day buy a supercharger kit... just wishful thinking, don't quote me...
jdm-planet.com
On burger website there is instructions on the install also they have videos on YouTubeIt’s there any video for installation in GV80. Can’t wait to install mine.![]()
Appearently you have no idea what you are talking about. Piggy back controllers like the Burger do not tell the the engine to make more boost or add more fuel. Instead they simply tell the engine that it is not making enough boost or giving enough fuel. The engine management electronics believe they are doing exactly what they are supposed to, therefore there is nothing for the factory to look at.Anything you do that modifies the engine boost and parameters will void your warranty. Hopefully none of us do have an issue, but if anyone thinks for one second the factory won't be able to tell the engine was "told" to make more boost and "add" more fuel they are up in the night. You have to pay to play. JMO
Apparently I do have an idea of how they work. The engine neither makes the boosties or adds the extra fuel. I'm aware the controllers calls for more psi and fuel but the sensors that tell you how much boost is being made do not lie. The fuel system also does not lie. I'm aware that the system can be removed and made to look like it was never there. I also know if a car company selling $70,000 cars has one come back to the dealer with engine issues, transmission issues, or drive line issues, they will pull out the microscope. That's when it is your time to either lie about it or man up and deal with it. I am not the moral police. Just a guy that tries not to spread false information.Appearently you have no idea what you are talking about. Piggy back controllers like the Burger do not tell the the engine to make more boost or add more fuel. Instead they simply tell the engine that it is not making enough boost or giving enough fuel. The engine management electronics believe they are doing exactly what they are supposed to, therefore there is nothing for the factory to look at.
