jetrep
- Jan 27, 2021
- Location
- Southern NV
- Genesis Model Year
- 2019
- Genesis G70
Has anybody with an LSD equipped differential changed their diff fluid?  The manual calls for this to be completed at 36k miles for LSD equipped models.  I haven't had much luck finding exactly what should be used.  I don't particularly care for my dealer so I have not yet asked them.
For the gear oil itself I've found Redline 75W85 GL-5 75W85 GL-5 Gear Oil
Per the manual:
1.47 US QTS (1.4L) required HYPOID GEAR OIL API GL-5 SAE 75W/85 (SK HK SYN LSD GEAR OIL 75W85 or equivalent)*
* Be sure to inject for exclusive use of LSD when replacing Rear Differential Oil (if equipped with Limited Slip Differential)
The manual I have specifies the same oil for both front and rear differentials in case anybody is wondering. Rear diffs with LSD require an additive (this is common for clutch pack style differentials).
I don't have AWD so don't have much to contribute there but I figure I'll mention that the transfer case uses different oil (SHELL TF 0870B)
Per the manual:
