EdVoylesHyundai
I went to a Genesis training course today and had the opportunity to learn some things about it as well as fiddle with a couple of them. Alas, we were not allowed to drive them at all. There were 3 cars present, but only 2 were available for playing with. The third was just present. All 3 had different wheels. One had 17's and 2 had 18's. They all had a "pre-production" grille which I was promised was not the one we will see on the production model. According to our instructor, we will not see Adaptive Cruise Control or Electronic Parking Brake for awhile as there are some quirks to the system that make them bothersome to operate. The "feel" of the car is similar to the Azera. The steering wheel felt a little plasticky, but the rest of the interior is top notch.
Both cars had the Nav system, but one car had the Tech Package and the other didn't. The "iDrive" system is easier to operate than I anticipated, but I still prefer a touch-screen style setup. The Nav in the Genesis is NOT touch-screen at this point. That is what the knob is for. The voice-recognition stuff is neat, but it is quicker to hit the button for me. I guess if there are some functions which require several button-pushes but only a single voice command, it would be worth it saying it.
The cooled driver seat is going to be a very nice touch in the South or anywhere it gets hot. The seat gets nice and frosty in a fairly short period of time.
The Adaptive Front Lighting System is neat. It does auto-level when the vehicle is started, which looks cool in the garage. I am sure it will look even better in the dark of night. A replacement headlight (not bulb, but whole unit) is rumored to be $1500-1800. The AFLS uses 2 vehicle height sensors (one front, one rear) to determine how high or low to aim the headlights upon startup. The headlamps use inputs from the wheel speed sensors, steering angle sensors and transmission sensors, among others, to determine the angle they need to rotate when cornering. The inside headlight will rotate up to 15deg and the outside headlight will rotate up to 7.5deg. Its a neat system.
The 3.8 V6 is dubbed the "Lambda II" and "no parts are interchangeable" between the Lambda and Lambda II engines. The 30 extra hp come from the Dual CVVT vs the Intake-only CVVT. Compression ratios, bore, stroke, etc are the same between both engines. Redline (IIRC) was 6500 on the two cars I sat in today.
There are no adjustable pedals available on the Genesis, per our intructor.
Battery is in the trunk for numerous reasons and there is a handy-dandy jump-start hook-up under the hood.
The plastic engine cover is hugely huge and the valve covers and intake mani are both plastic.
Electro-hydraulic Power Steering to be used on the V8 only. V6 gets traditional Hydraulic system. The Electro-system in the Genesis is completely different from the fully electric assist system in the Elantra.
The A/C and Charging systems are unique. The A/C compressor does not have a clutch. It is always turning. It uses an Electronic Control Variable Swash Plate to control the compressor pumping. The charging system has a bettery tester built in and will let the alternator free-wheel when the battery is more than 95% charged and the system load is low. This saves fuel.
I could go on and on about this car. I have the training materials here. If you have questions, let them fly. I will do my best to answer them. I'll post some pics I took in a bit.
