Man, I am finally nearly ready to start my engine. I am finishing up the AC system. I got everything button down, but I need to change the desiccant filter pack in the front condenser in front of the radiator. The desiccant pack needs to be changed when the AC system has been opened to air. I am waiting for a OEM replacement and then I can pull a vaccum to recharge the AC system.
The desiccant pack is located on the passenger side of the condenser inside a chamber sealed with a 10mm hex cap filter. The desiccant pack is basically a larger version of the smaller packs located in shipping boxes and food packages that absorbs air and moisture.
The AC system reinstalled; except for the desiccant pack.
The desiccant pack in the condenser. You have to use some long tipped needle nose pliers to pull it out the chamber.
The desiccant pack and filter cap with the needle nose pliers I used to pull it out.
