CurbRash
- Jul 1, 2024
- Genesis Model Year
- 2020
- Genesis G70
Your posts have been super helpful in my search for new rims. A couple q:those widths and tire sizes will fit, those sizes are a bit thin for 8.5 and 9.5 though. 245 and 265 would be ideal if you can do it.
as for the front, unfortunately not sure if it would fit with no rubbing. maybe the thinner tire would mean the sidewalls stand up less straight than mine do, therefore avoiding the point on the outside of the tire that hits my inner fender liner. but i don't know.
-you have a 3.3 AWD right?
-your front tires rub on the streetside/outside of the tire, correct?
-if I ran the same wheel and tire sizes but with a 35 offset, no rubbing I’d guess? It would protrude 7-8mm past the stock wheel size on the inside, any issues you see there?
-I’m not on coil overs but I am getting the eibach springs installed. (And white line sways, but not so relevant)
I’m hoping to make these work:
store.superspeedwheels.com/en-ca/products/flowform_rf06_mb
in 8.5x19 +35 and 9.5x19 +33 with the same tires as your setup.
Thanks!
