lisaannweaver721
- Oct 9, 2024
- Genesis Model Year
- 2012
Yes my 2012 genesis sedan 3.8 is doing a similar issue and it won't start but right as I push the start /stop button and brake pedal the lights flash on the instrament cluster and the everything stops and 8 get nothing but complete power loss from everything and I'm at a huge loss as to why this is happening.I have a 2009 Genny V6 sedan with about 82K. Owned since 2012. Love the car.
A few months ago the problem began and I can't figure out why or what is causing it. I did a search but didn't find anything related to my issue. Maybe I missed something during the search. any help would be appreciated.
I hope to describe the issue effective:
The car sometimes doesn't start when pushing the "start/stop" button. All the dashboard lights will light up and the steering wheel will move into 'driving' position but the engine wont turn over...nothing at all. It's like the brake pedal isn't pushed in. push the button again and everything turns off. Push a third time and then the engine may start. (sometimes not - repeat procedure). Push the brake harder, hold the start/stop button longer. All of these do not seem to affect the issue.
As the few weeks go by, the problem began to be more common. and recently it is just about every time I try to start the car. The car battery was replaced about a year ago. I've changed the battery in the remote keys, tried both sets of keys, and even installed the key fob in the dash-holder before starting. The same intermittent starting issue would happen no matter what I try differently.
I wonder if a button on the brake pedal (to tell the car the brake has been engaged) is not making good contact. It appears the remote is talking to the car but the starter or brake pedal is not communicating as it should. Or is there something else I'm missing?
Has anyone had experienced the same/similar situation?
Thanks.
I'm still having the issue.NJTom, whatever became of your intermittent starting issues? How did it get resolved?
I am having the same issue on 2015 3.8 Genesis ultimate AWD.
thanks
I have no idea what is the cause of not starting and I really need help since I got my car it's been a lot of extra money on top of the purchase price just to fix the transfer of title and registration from fraudulent issues I was not aware of and then it turns out there had been an odometer rollback that I was unaware of so there ended up being over 200k miles on it but the odometer says 130k miles and the front a arm bushings are completely worn out and digging in to my frame and I have no way to fix this and I'm also having a not starting issue. Please everybody if you can I really don't know what I'm going to do and my car I love my car but I'm stuck where I'm going to have to non op it or sell it to a junk yard or find a helping hand so to speak so if anyone can and will help me with these 2 things I will be forever grateful and I will even cook you a nice juicy bone in ribeye steak and not to brag but I can cook a screaming ribeye steak that's to die for.I am having and have had the same issue that the OP described with my 2013 3.8 Sedan. Every time I take the car in on extended warranty, they cant reproduce the issue, of course. I have another year left on the warranty but they literally give me the same run around at 3 different dealers in a couple hour radius. Start button, brake switch, and sensors have either been tested or replaced. Any ideas so I don't have to get rid of this amazing car?
That sounds just like mine ,only problem is I have no more money and I can't even borrow that much and I lost my husband last may due to ALS DESEASE and he took care of me and he was the only one bringing anything in to pay for the bills cause I'm disabled and SSD keeps denying me so I'm strapped s9 need another options.Most likely starter motor is bad. Similar thing happened to me with newer Genesis with less miles.
Push button, nothing. Wait a minute, then push again, it would start. It happened a few times, then eventually didn't start at all.
