The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Do you know this for a fact or just assume it? This contradicts what I was told at the dealership.The key does not start the car
Yes, I know all that having read the manual.... its for the trunk and doors when the fob battery is dead or if and electric lock is not working. Also its for locking the glove box.
....little square cover in the tranney tunnel near the driver.
Holy crap lets put this baby to bed.
There is NO physical key-in-ignition for the Genesis Sedan. The keyfob HAS to be present to start the vehicle. If the keyfob is DEAD put the fob in the slot in the dash and the car will start.
The keyfob has to communicate with the car in order to start. If the fob dies, it can't communicate with the car. The slot holds a device that recognizes the fob and allows the vehicle to start.
The physical key in the fob is for doors/trunk/glovebox only.
That is the long and short of it. I worked for Hyundai when these cars hit the market and was the resident Genesis expert before moving on in life.
OneFun
And some folks will do anything to avoid reading an entire thread.Some folks will do anything to avoid reading a manual.
It was, as I'm pretty sure yours would be if you had one, in my left front pants pocket. Let's give a conservative estimate and say 2 feet away. It was then pulled out, inserted into the dash slot, pulled out, buttons pressed, taken outside the car and brought back in the car and several other scenarios tried before it would start the car again. When the car was restarted the message changed to (paraphrasing) 'the key is not in the car' which also was not in the manual.^^ If the key is too far away from the ignition the car wont start. It's not just if the key is inside the confines of the car, it's where is the key in relation to the ignition.
It is/was not dead and is now/was after 15 minutes communicating properly.If the key was within range of the ignition and it still wasn't starting, then the key might be dead or not communicating properly.
The fob can be inserted into the slot in the dash if the fob battery is dead. The key does not start the car, its for the trunk and doors when the fob battery is dead or if and electric lock is not working. Also its for locking the glove box. All is explained in the manual.
First, I'm pleased you took my suggestion and read through the entire thread.If you know all that and you did read the manual, then you know how use the pull out key. The manual describes its only uses. Perhaps your salesman can show you another place to put it, though.
Where is this slot.Holy crap lets put this baby to bed.
OneFun
FYI-That slot does not exist on the base model 3.8LLower left of the console right by where your right knee would be (unless you drive on the wrong side of the car). There is a small flapping door that the fob can be inserted into.
