QuantumRift
Yea the PRICE is now $299.00.
I have a 2012 Genny Sedan, prem/tech pkg. SO you are saying this is an 'easy install' ...I'd like to do it myself and save whatever it is they charge at the local car audio shop, but I don't want to get into a lot of screws and plastic laying about.
The tech there at the NAV-TV says that there is very little room to install the device. Also, it appears to have a USB port for 'updates' , so I would also like to hang a USB pigtail out of it to access after I get it installed. Also, since heat seems to be an issue in the dash, would installing this restrict air flow in any way?
I just want to be sure I can still access NAV, SETTINGS, RADIO, XM screens after installation....my wife wants to watch DVD on long trips, and I don't want to lose ability to see NAV and other displays.
Hey Warp08,
I purchased the mod from NavTV serveral months ago for my 4.6 tech package. It was sent directly to a stereo shop here in Atlanta. It had to be sent back twice because NavTv had only done one Genesis at that time, and they said the tech forgot or couldn't remember exactly how he constructed the modual. The first time that they sent it, it did not have Voice Command. But when they sent it back, it worked fine. I have full voice command/bluetooth with VIM. Hey check this out, it is a plug and play, and they send the instalation instructions with it. Had I saw the instructions first, I could have installed it. You pop the face plate off using a piece of hard plastic, remove two philips head screws, and two 10mm bolts. Then dis-connect the factory harness, connect NavTV's harness. The stereo shop charged me $75.00 bucks to install it. Works great. You need to let them know that the Voice Command doesn't work.
Thanks
