difference between 5.0 genesis and r spec genesis
deepcolor
does anyone know if the 0-60 times are different? shifting different?
both have 429 hp, so besides the different suspension, tires/rims/mats/rspec emblems/ etc. what's the difference (if any) in the performance stats?
There is probably a difference in transmission shifting or gear ratio's. The R-Spec EPA MPG ratings are about 1 MPG less than the 5.0.
I always wondered that myself, I have a 5.0...but not a R-SPEC
According to Hyundai, the non-cosmetic differences (like exterior and interior color choices) are:
R Spec vs. Non-R Spec
  • Wheels: Alloy Wheels, 19-In. X 8.0-In. vs. Alloy Wheels, 18-In. X 7.5-In.
  • Tires: SBRP235/45R19 vs. SBRP235/50R18 Tires
  • Front Suspension: Independent Multi-Link Front Suspension With Coil Springs, Sachs® ASD Gas Charged Shock Absorbers and Sport Ride Type vs. Independent Multi-Link Front Suspension With Coil Springs and Sachs® ASD Gas Charged Shock Absorbers
  • Rear Suspension: Independent Multi-Link Rear Suspension With Coil Springs, Sachs® ASD Gas Charged Shock Absorbers and Sport Ride Type vs. Independent Multi-Link Rear Suspension With Coil Springs and Sachs® ASD Gas Charged Shock Absorbers
  • Front Stabilizer Bar: 26-mm Front vs. 25-mm Front
  • Rear Stabilizer Bar: 19-mm Rear vs. 18-mm Rear
No other changes are mentioned in the specs that were released (at least to my knowledge) except that the final gear ratios are exactly the same for the R Spec and Non-R Spec, both.
I don't remember Hyundai explaining what "Sport Ride Type" means, exactly. LOL
If the gear ratios are different (not just final ratio) then the shift points must be different since the R-Spec gets 1 MPG less than the 5.0.
Suspension and its tuning including the 19 in wheels and summer tires are the mechanical differences, the rest is understated badging (floor mats) and a badge on the rear of the car. Supposed to have a more sporting transmission shift pattern but hard to determine what that constitues. I have a 5.0 and it runs great, the ride is a bit choppy/firm but liveable, and not as harsh as the R-Spec is supposed to be. Otherwise a fine car - but not listed as a choice on this forum.
LenP5.0:o
oh.. you forgot the wonderful designer r-spec floor mats :)
I like the regular GENESIS ones better to be honest.
I may buy an extra set of GENESIS ones and save the OEM R Spec's for when I sell the car.
larger tires/rims will result in lower gas mileage this is why they show it 1mpg less.
ppp
Wider tire does decrease MPG, but do you think that accounts for the 1 MPG less on the R-Spec? How about different transmission shift points?
Aren't the R-Spec brakes slightly larger?
I think Mark is correct The wheel/tire differences are not significant enough to account for 1 mpg. Having driven both cars, my opinion most of the difference is the shift points are modestly higher into the power band on the R-Spec.
I dont see how highway MPG can be affected by the transmission at all, unless the final drive ratio is different (which I don't believe it is).
In addition to wider tires meaning more rolling resistance, unsprung weight increase with the R-Spec is probably significant too.
Higher shift point=higher RPM=higher MPG
Nope.
The 4.6, 5.0 and R Spec all have the same size brakes (front and rear). The 3.8's front brakes are smaller by 0.6 inches - rear brakes are the same as all the other models.
wondering if the 5.0 non r spec can also acheive the same 0 -60 times as the r spec; or will the lower shift points make a difference ?
Nope.
Also to note is that all the 2012 models received larger brakes vs 2009-2011 models.
