The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
does anyone know if the 0-60 times are different? shifting different?
both have 429 hp, so besides the different suspension, tires/rims/mats/rspec emblems/ etc. what's the difference (if any) in the performance stats?
If the gear ratios are different (not just final ratio) then the shift points must be different since the R-Spec gets 1 MPG less than the 5.0.According to Hyundai, the non-cosmetic differences (like exterior and interior color choices) are:
R Spec vs. Non-R Spec
No other changes are mentioned in the specs that were released (at least to my knowledge) except that the final gear ratios are exactly the same for the R Spec and Non-R Spec, both.
- Wheels: Alloy Wheels, 19-In. X 8.0-In. vs. Alloy Wheels, 18-In. X 7.5-In.
- Tires: SBRP235/45R19 vs. SBRP235/50R18 Tires
- Front Suspension: Independent Multi-Link Front Suspension With Coil Springs, Sachs® ASD Gas Charged Shock Absorbers and Sport Ride Type vs. Independent Multi-Link Front Suspension With Coil Springs and Sachs® ASD Gas Charged Shock Absorbers
- Rear Suspension: Independent Multi-Link Rear Suspension With Coil Springs, Sachs® ASD Gas Charged Shock Absorbers and Sport Ride Type vs. Independent Multi-Link Rear Suspension With Coil Springs and Sachs® ASD Gas Charged Shock Absorbers
- Front Stabilizer Bar: 26-mm Front vs. 25-mm Front
- Rear Stabilizer Bar: 19-mm Rear vs. 18-mm Rear
I don't remember Hyundai explaining what "Sport Ride Type" means, exactly. LOL
I like the regular GENESIS ones better to be honest.oh.. you forgot the wonderful designer r-spec floor mats![]()
larger tires/rims will result in lower gas mileage this is why they show it 1mpg less.
ppp
Wider tire does decrease MPG, but do you think that accounts for the 1 MPG less on the R-Spec? How about different transmission shift points?larger tires/rims will result in lower gas mileage this is why they show it 1mpg less.
I dont see how highway MPG can be affected by the transmission at all, unless the final drive ratio is different (which I don't believe it is).
In addition to wider tires meaning more rolling resistance, unsprung weight increase with the R-Spec is probably significant too.
Higher shift point=higher RPM=higher MPG
Aren't the R-Spec brakes slightly larger?
Nope.
The 4.6, 5.0 and R Spec all have the same size brakes (front and rear). The 3.8's front brakes are smaller by 0.6 inches - rear brakes are the same as all the other models.
