So I have discovered a few issues with this update:
1.
Carplay will not launch if your phone is locked, even with the option set in the phone to use
Carplay while locked, since the 12.5 update my phone pops an alert that says "unlock to use this accessory" when I plug it in. Once I unlock, then
Carplay will connect, it will not connect until I unlock the radio just flips to FM. As soon as I unlock it connects and flips back to
Carplay, once the screen times out and relocks if
carplay is active (i.e. I am playing music or using the apple maps or another app) then it continues to work.
If I continue to listen to the radio and don't actually go into
Carplay, it will not work until I unlock the phone.
2. The radio pauses/mutes when I change gears or activate the front camera. I have a habit of hitting the camera button when I pull into my office or home driveway, the camera activates once my speed is below 9mph, when this happens regardless of what source I am using the radio "hiccups" the sound cuts out, then back in, then out then back in, 2-3 times.. I can replicate this every time.
the same "hiccup" occurs if I got from Park to Drive or Drive to Neutral. Obviously Park or Drive to Reverse reduces the volume so the hiccup is not noticeable.
Lastly, prior to this update, when I exited the car (power off and open door) whatever source the radio was on when I did this (
Carplay, FM, XM, Bluetooth, whatever), when I restarted the car, after the "confirm" screen, the unit would return to that source. Now it will only go to the map screen, and I have to hit HOME then choose my source.
Also I have noticed if I was using
Carplay when I turned off the car, when I restart; it is in Jukebox until
Carplay connects, if my phone is unlocked when I connect it, then after 20-30 seconds it will pick up
Carplay and switch from Jukebox to
Carplay and continue playing from where I left off, if my phone is locked it will continue in Jukebox until I unlock the phone.
before the update the radio was just silent until
Carplay was connected, if
Carplay was the last source used at shutdown.
none of this is major critical but #1 requires an extra unneeded step IMO, and #2 is just annoying.
