2015 turn signal burnout problem
dbbalch
Maryland
Another reason why I do not want to deal with resisters. Heat and no place to install them without melting the plastic lighting housing. Plus, I can imagine the the resistors will fail due to the heat and fail probably before a set of 2357NA bulbs. So, not a real solution to the bulb burnout problem if the resistors do not last. Hyper-flashing is not an option for me.
All very true. the higher-wattage (5.6W) LEDs turned out to be the solution for me - hyper-flashing does not happen now.
carguy75
247
43
Atlanta, Georgia
Sound as like you use true error-free/non-hyper flashing LED bulbs that actually works in our lighting system without issues. Time will tell if the LED bulbs can last being used as DRL. Some LED bulb circuity will fail due to heat production if they are not properly thermally protected for the application. The LED bulbs you use may work fine as signal bulbs, but fail prematurely when used constantly as an DRL.
I had a similar LED bulb in my Cadillac being used as an DRL, the bulb failed in just over a year of use. To the LED bulb manufacturer credit if was listed to be a signal bulb only. I had to replace it with a LED bulb that supposed to be thermally protected to reduce heat damage. However, even the LED bulbs I have now is listed as signal bulbs as well; so time will tell if they hold up pass a year of DRL use.
Hopefully, those LED bulbs you have are designed to go the distant as DRL, but the more watts the LED bulbs produce make the more heat. Heat damages small LED circuitry.
dbbalch
Maryland
You might want to try different LED brands to see if the hyper flashing stops. Mine seldom hyper flash, only sometimes sitting at a long light, then a quick off/on and they're back to normal
Advice taken. Did a little more research on the topic of lights and got these. They're one of the few I found that explicitly state DRL as a use case. They work great - no hyper flash at all under any circumstance. I spliced new 1156 sockets onto my harnesses and made them longer, hence the lights below. Stock sockets take 1157 bulbs.
CK Series LED Exterior Light-1156 Amber
surprisinguy
65
NC
Thanks for an extra light source... guess when mine finally quit I could try these out, maybe just do a dab of solder on the bottom of some 1157s to bridge them so i dont have to switch out the sockets. To be honest I'm not sure how much of a modification needs to be done to a light anyway... didnt even check when I put mine in to see if the whole light lit up or not!
Suburbazine
SUPPORTING MEMBER
229
70
Louisiana
dbbalch
Maryland
I read this thread with great interest because I too have had to change my front turn signal bulbs many times - more than on all the other cars I have ever owned, combined. This is unacceptable to me on any car. It is especially annoying on this car given all the effort required to change the passenger side bulb. I tried installing LED bulbs as a quick fix, but they didn't work. That set me on a mission to understand why and the findings are interesting, so I wanted to share.
The signal lamps in the "Type B" assemblies of the 2015 Genesis (attached) double as turn signal lights and daytime lights (DRLs), but they are not dual-function like a brake light (turn on, get brighter). They are single-function lights (turn on). If you activate a turn signal when the DRLs are on, the light will pulse on and off, not on, then brighter like a brake light. This is where it gets weird.
Instead of using a standard single function two-wire 1156 socket, my Genesis has modified two-wire 1157 sockets. So, only one of the two contacts and filaments in the 1157/2357 bulb is ever used. If this light was only being used as a turn signal, nobody would care. But the much higher demand of the DRL role is cooking through the limited lifespan of these bulbs, which has opened the door to using LEDs. And because they are using only one contact in a dual-contact socket, 1157/2357 LEDs may not always work.
To my knowledge, the two-wire 1157-style sockets in these headlight assemblies are a Hyundai-only part. I have no idea why Hyundai chose to modify a dual-function component to accommodate a single-function electrical requirement.
I am replacing my factory sockets with standard two-wire 1156 sockets that accommodate single-contact/single-filament bulbs. My hope is that the corresponding 1156 LED (https://www.amazon.com/SYLVANIA-ZEVO-White-Contains-Bulbs/dp/B01A77QQTE/ref=sr_1_14?ie=UTF8&qid=1548694505&sr=8-14&keywords=1156+led&th=1) will work without issue; they only pull 1.5W compared to the 21W of the 1156 incandescent and are much more appropriate for the always-on load of a DRL.
I'll post an update with the results.
UPDATE:
The replacement 1156 sockets work just fine, and the longer lead wires allow me to pull the passenger-side socket clear of the air cleaner box if I ever need to change the bulb. I settled on these bulbs, which have functioned flawlessly for well over a month. That is, they do not hyper-flash and they appear to have the durability to be used as DRLs.
If I ever go back to the stock 1157-style stock sockets, I would go with the 1157 version of this bulb.
kibber
12
A potential downside seems to be that now you may have blindingly bright turn signals at night. 1200lm is seriously bright!
Suburbazine
SUPPORTING MEMBER
229
70
Louisiana
Suburbazine
SUPPORTING MEMBER
229
70
Louisiana
kibber
12
That's if you're dealing with a white, untinted bulb. The amber filter significantly cuts output.
Word on the interwebs seems to be that it should still be around 300lm for the amber incandescent.
The same applies to white LEDS, they will almost always have much higher luminosity than their colored equivalents. Many LED lamp sellers will misuse the white specs on their colored chips.
Yeah, I ran into that problem with SuperBrightLEDs, although in their case the low lumens (90lm for the amber version as opposed to 420lm for the white one) were listed on the spec page, I just didn't get to the fine print.
dbbalch
Maryland
The LEDs are somewhat brighter, but my primary motivation is greater longevity. Time will tell...
Work4You
I am interested in making the modification. Can you let us know where you got the 1156 sockets from, and if there are any mods that need doing for them to fit in the housing?
Thanks,
Smobien
15
Northern Virginia
Thanks,
Read this thread.
