2017/2018 radio swap in 2016 ultimate?
This! Heated steering wheel for the masses.
So just a recap. A 2017/2018 G80 9.2 DIS head unit and matching Amplifier would technically get you Carplay/Android Auto with sound but it isn't cheap.
Does anyone have any resources on finding salvaged/totaled Genesis G80 parts? I found a site called car-part.com but i've never used it.
It is showing a Genesis G80 Radios and Amplifiers between $70-150
It does work since the Koreans figured it out already as shown earlier in the thread
Theoretically, there could be a software solution. Unfortunately, it's remained elusive despite earlier promising efforts...
I saw the earlier videos and posts proving that it works. (Ps: Great work everyone!) Now it's the implementation portion of it which i'm getting stuck on. How to get the required parts and obtaining the installation steps.
I'm assuming that I'm in the same boat as others who want this additional functionality but not wanting to spend $2000+ on new OEM parts. I just have never played the salvaged/junk yard used car parts game so I'm just curious if anyone has a preferred site to get the DIS and AMP from a totaled 2017/2018 G80.
One of us copped a working Ultimate H/U for cheap - the seller prob didn't realize the diff between it and the Android unit. The 'droid is usually WAY cheaper.... No one managed a cheap amp as of yet though.
I thought the 2017's still use the incompatible hardware, no? It wasn't until 2018's that the Ultimate Trims where Apple Carplay and Android Auto became commonplace.
I think '17 is when it became available... If I remember correctly, the "old" head unit would boot with the newer software but no sound, because the "new" amp couldn't be found.
Yep, it's almost entirely an amp problem right now- however, the firmware between the head units is different as well and enables certain features for Carplay at boot time.
I still need to find an aftermarket amp to see what the differences are, but apparently the Koreans are doing finding them and adding some wires.
Possibly a dumb question but do you need to pair a 2018 Ultimate Head unit with a 2018 Ultimate AMP? I know it's mandatory to have the Ultimate Head Unit because of the heads up display but would a lower trim (Non Ultimate) 2018 G80 Amp work?
Probably not - The non Ultimate has a 14 speaker setup, Ultimate has 17. It's likely looking for that amp to ID itself on the CAN Bus.
Won't work. Has to be the part number ending in -B1550 to communicate.
Now that there should be some idle hands out there, who's going to pick up the ball on this again? I don't have any programming skill.
Unfortunately most of those same hands are required to keep critical systems humming along, while being stretched beyond their designed limits during these exciting times...
Unfortunate, but true.
