mtrot
- May 20, 2013
- Location
- East Texas
- Genesis GV80
When you say there are only two OEM filters for the Genesis, you are correct. The one with black end cap is made by Mann-Hummel, and the one with whiter end cap is made by Mahle. The newer V8's specify the Mahle filters. I know that in 2009, the only filter available was the one from Mann-Hummel with black end caps for both the V6 and V8.
mtrot is talking about an after-market oil filter, not branded Hyundai or not one of the after-market filters (also made by Mann-Hummel or Mahle) that are identical to the OEM's. In theory, some other company could make a high quality after-market filter for the Genesis that is as good or better than the OEM (or after-markets that are identical to the OEM), but in this case the filter he got at the quick lube is junk. The filter that mtrot got at the quick lube is probably the correct filter in terms of specifications, but it is just a piece of junk. It is not the OEM filter with black end caps made by Mann-Hummel. Quick lube places typically use filters that cost them about $1 or $2 at most, and you imagine how bad the quality of these filters are, and whenever I have gone to a quick lube (prior to owning the Genesis since I now do my own oil changes) I have always brought my own filter (OEM or quality after-market).
OK, interesting visit to the oil change shop today. I have been using this filter from Amazon for some time:
[ame="http://www.amazon.com/gp/product/B0068MWZCK/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1"]Amazon.com: MAHLE Original OX 351D Oil Filter: Automotive[/ame]
The last time I purchased I ordered two of them. I had the first of them installed with no problem a couple months ago. So, I went to the shop today to have the second one installed, and the tech brought me both the filter they removed and the filter I had brought today. He stated that the filter I brought today did not fit the car, which I thought was darn strange, since I had ordered two of them from Amazon on the same order.
Upon inspection, the two filters are indeed different. The filter they removed appeared to have the black end caps, while the one I brought has white end caps.
What he told me is that on the one with the white end caps, the diameter of that inner hole is too small. And it does indeed appear to be smaller than the hole of the one they removed.
Now, the listing on Amazon still has the confirmation at the top that the filter DOES fit my 2012 Genesis 4.6. So, I am really confused now as to which one I should order in the future. If not from Amazon, what source do you recommend? Thanks!
