AllMotorIsBestMotor
- Dec 18, 2024
- Genesis Model Year
- 2020
- Genesis G70
Hi all, back in September I bought a 35k Mile 3.3T AWD Prestige and had the dealer replace the rear LSD fluid with the fluid Genesis recommends (it had never been done before) per the maintenance schedule in the manual.  Of course I thought I was doing the right thing and now I'm 2 replacement LSDs in and have an appointment tomorrow for what I'm 100% certain will be a 3rd placement (so fourth rear LSD) in the car.  Lots of chattering, grinding, shuddery turning on throttle at low speeds, etc.  After the second LSD was replaced I made the senior service advisor aware of the TSB for the Stinger GT and GV70 rear LSDs specifying additional friction modifier and they did confirm this but said that they cannot follow this TSB for the G70 because Genesis does not have the same TSB for it.
What are the odds I can get Genesis Corporate to authorize the proper fix for this car if I open a case with them? Should I just have them put a new diff in and try the Amsoil Severe Gear and Slip Lock additive as soon as I get the car back? How has this worked out for those of you that have gone that route so far? Has this fix lasted long enough to seem like a permanent solution? My 3rd diff went the longest before making the noise after replacement with the OEM fluid but it did eventually go again after maybe 5k miles.
I bought the car with an extended bumper to bumper warranty so thankfully I'm covered on the diff for 4 years and another 50K miles but I need a permanent fix or I'm going to have to ditch the car which I really don't want to do.
Thanks in advance.
Thanks in advance.
