The new (2012-2013) Rear Stabilizer bar is larger, but now hollow. This allows the rear wheels to act more independently of each other without sacrificing control. The results is that rear wheels should stay planted on the road better than before (unless the road is smooth, in which case no real difference). Someone else on this forum first mentioned that there is only one Rear Stabilizer bar for all trim levels starting in 2012 (3.8 and R-Spec). When I check on
www.newhyundaiparts.com I can found the same info since only one Rear Stabilizer bar is listed with the designation of "All" (fits all trim and engine sizes), and that the same bar is used for 2012-2013 model years.
http://www.partswebsite.com/newhyun...ection=24&catid=30158&subcatid=30545&fl_id=50
The new rear Stabilizer Bar would probably benefit anyone with a 2009-2011 Genesis.
As you probably know, starting in 2012 the regular Genesis (non R-Spec) got a somewhat softer and more comfortable suspension. However, the R-Spec is still pretty firm like all the 2010-2011 Genesis sedan trim levels. My guess is that the 2012-2013 R-Spec just retained the 2010-2011 springs, shocks/struts, and only replaced the Rear Stabilizer bar to be a bit firmer than 2012-2013 non R-Spec models. If that is the case, replacing the springs, shocks/struts on your 2010 (non R-Spec) with 2012-2013 R-Spec springs, shocks/struts, may make no difference at all.
OTOH, for scottdk, who has a 2009, replacing the springs, shocks/struts (he has already replaced the Rear Stabilizer bar) should yield a noticeable improvement (just as I noticed improvement on my 2009 when I upgraded to 2010/2011 springs, shocks/struts).
If you want a stiffer spring, only option may be one from 2009, but I don't think you can order one from Hyundai anymore. Maybe scottdk will sell you his. However, the 2009 springs overpower the shocks/struts, and the results are not good IMO.
