Driver Seat power functions not working on 2014 sedan
splooge
I have a 2014 Genesis sedan that had minor fresh-water flood damage to the drivers side. I replaced all the seat motors and seat switch, but only the seat-back recline works (did not have to replace this motor). I have the seat's under side exposed, should I put some grease on each of the connectors? My car is not warranted, so a visit to the dealer would come out of my pocket. Any assistance would be appreciated.
Thanks,
Splooge
obvious/dumb question: did you check the fuse?
Yes, the 30 amp fuse under the hood is good. I purchased a new seat switch, and I recently checked the connections from the switch contacts to the plug, with the same outcome. The front of the seat will raise only and the rear of the seat only goes down. And the seat will not move from front to back. I will unbolt the seat from the frame "again" to test connections to the motors. :(
