descartesfool
- Mar 9, 2024
- Genesis Model Year
- 2024
- Genesis GV70 EV
40,000 cycles in 8 years? Not really relevant for an EV. In 8 years there are only 2920 days. If you drive 100 kms per day, you might be charging every 3 days so that's less than 1000 cycles. Likely most people would be using much less full charging cycles in 8 years, perhaps 500-750. NASA stuff might be interesting for satellites, but for me something from Genesis on their own batteries is more relevant. The battery charging is controlled by the car's ICCU and monitored for temperature and rate all controlled by a battery conditioning unit. It would be nice to see something from Genesis that there might be a battery longevity issue with AC charging at 11 kW or less to 100% charge. The lower the charge rate, the lower the heat generated in the battery. DC charging at a 50-350 kW rate is vastly different than 6-11 kW AC charging rate. I found nothing in the owner's manual or any Genesis online document related to battery longevity vs AC charge %. EV Battery warranty is for 8 years in Canada and covers battery capacity being at least 70% of new. The expectation is that battery capacity goes down over time based on usage, but by how much actually.
