We have the 3.8 AWD. Has about 4500 miles. Was going to change with full synth at around 6K. Dealer gave me first oil change (after 6mo) free but didn't specify synth or reg.
Once dealer changes it I'll probably change myself as I engoy doing it - unless full syth price is too reasonable to ignore etc.
When has everyone changed theirs and how much for full synth.
BTW, car has been great. Build date was end of Feb
Thanks
Let the dealer change the oil now (probably regular, or synthetic blend at best), and then switch to full synthetic as you planned after about 3000 more miles.
I use Mobil 1 5W-30 Extended Performance, at about every 5000 miles, but I only drive 5000 miles or less per year. The most you can go between changes (for warranty purposes) is 7500 miles or 1 year. Despite what some think, Mobil 1 EP has benefits other than being able to extend the oil change drain interval (which you can't do, because of the warranty). I have also used Mobil 1 0W-30, which would be good for colder climates. Mobil 1 prices are cheap at Walmart, as I suspect you know.
Get the OEM oil filters from dealer, either in person, or online (such as Jim Ellis Hyundai in Atlanta). The oil filters are the cartridge type, so don't try and find an after-market filter, since they are either identical to the OEM filter (made by Mahle) or are inferior.
Although the V8 specifies 5W-20, I believe the 2015 specifies 5W-30. As I mentioned, Mobil 1 0W-30 is fine.
You will also need some air filters and cabin filters, so stock up on everything at one time for the next several years to lower the cost of shipping or driving to the dealer.
I keep all receipts, including the product bar code from the oil filter box. I keep a spreadsheet of all maintenance. I also go onto
www.MyHyundai.com and log all my maintenance activities on that site also.
