I replaced mine at about 40k. Depends on where and how you drive. When I lived in the city, I was happy to get 15,000.So this week I'm hearing a slight chirp grind when applying brakes on my 2015. I have 36,000 miles on it and I know during a tire rotation a while back a shop told me front brakes had worn quite a bit and needing replacing soon.
Local tire shop offers new pads and turn rotors for 165.00.
Price seems good but is 36,000 too early for a brake job, meaning i wonder if more issues hiding?
Never had "turning" work out. Might be the way I drive or just the fact that rotors are super cheaply made. If y'all don't want OE pads I recommend AKEBONO pads. They're really good and available almost everywhere.Don’t waste your time and money for turning them because you will end up replacing them right after and you will end up paying almost twice. Been there, done that.
My 2015 5.0 front brake pads were just at the wear indicator bars at 76K miles before I changed them. So 36k miles seem a bit premature based on my 2015 5.0 brakes pads. I have no experience with the 3.8 brakes; which may last longer or wear sooner.So this week I'm hearing a slight chirp grind when applying brakes on my 2015. I have 36,000 miles on it and I know during a tire rotation a while back a shop told me front brakes had worn quite a bit and needing replacing soon.
I never turn rotors,; I just replace them with the pads to prevent warpage and a pulsating brake pedal.Don’t waste your time and money for turning them because you will end up replacing them right after and you will end up paying almost twice. Been there, done that.
What shop in northern il did you get those from?FYI, I have the power stop's on my car now and the first set that I bought on amazon was actually for a G1 genesis not the G2. I found a few online stores that showed them fitting my car when they didn't. I contacted power stop to notify them that they have them listed for the wrong car and provided proof of the websites showing the wrong parts for my car and they did send me the new rotors but still said I purchased the wrong set and refused to acknowledge the issues online. That was July 2019 and I just order new rotors and pads from a local Hyundai dealer today as the power stops shake like mad when braking at speeds over 40. Maybe I got a bad set or maybe they are still not the proper ones for my car? Who knows but I got 40k from the OEM set before I started to feel some vibration and not even 10K with the power stops. They still look good though!
As for the OEM parts my dealer down the block wanted $500 just for the rotors and pads and another $200 to install them and wanted $40 for my broken dipstick. I found another dealer in northern IL and I got the rotors, pads and dip stick for $330+ tax. Shop around if you want OEM rotors.
Never mind. Google says Knauz Hyundai is permanently closed.What shop in northern il did you get those from?
As you found, there are several options. Try going to RockAuto and look it up. Look under "Brake Pad" and "Rotor" for your car. There are some higher end and more expensive parts, but the Daily Driver parts are just fine. I put a set of Centric on my last car (G37) and they were great.There’s so many differing options folks on this forum are suggesting, is there any reccomendation folks have for brand and part that seems to be the best result? I see Bosch, centric, Power stop, but I don’t know a whole lot about this and want to get something as good or better than oem. Ideas for a noob? Also, if I order pads/rotors online, do I need things like pins and screws and connecting harness stuff to bring to my local shop for install, or just the pads and rotors themselves?
I just bought the pads and rotors, no other parts, and paid for the install. I think I paid $150 or $200, can't recall - but it was worth it! My back thanked me.Also, if I order pads/rotors online, do I need things like pins and screws and connecting harness stuff to bring to my local shop for install, or just the pads and rotors themselves?
