Hyundai came thru - Messages on Premium NAV w/ update to 12.5
Any idea what is on the USB? Seems like they could offer it for download as well.
Here's the folder contents - There are some disk images in HU that I was unable to open
Thanks for this info! Everything except the .md5 file was in the download, but I had it in a Data subfolder on the USB drive. I will put everything where it goes and try the upgrade this evening.
My didn't "ask" for the USB stick while upgrading, I think that it'll prompt you if it's needed.
The update didn't work. I got "USB device not supported." Just to make sure, I tried with 2 separate USB drives. I wonder what checksum that md5 file is holding.
One odd thing: the old software seems to read the new map data. I see new roads around my house that were missing on the old map.
Mine just ran it off the SD card...
Could you share the contents of the md5 file? Should be a fairly small text file.
I'm not sure what to make of it - but here you go...
1005ea16eb27716252aeceaffad2bb34 *.lge.upgrade.xml
b37afe4988fa329cccc35bbe3c936acb *.lge.upgrade_enc.xml
e8abbeafd614d7dcbdeb073749a712e0 *AppUpgrade
85c8b2f535953731fa29027075c6be23 *essentials
806077cb59a29e2e771f5a3d777c5121 *IBOX.tar
60148134b7d195a9d9bc1e1d124b90f2 *HU\images\boot.img
9e8c7e91d1eddff8922b9eb1265abb21 *HU\images\vr.img
76689cee5aca41197952f272b05868f7 *HU\images\NP\rootfs.img
Thanks again! These are computed checksums to validate the completeness/integrity of each of these files. I'll try your values, and if they don't work, I'll recreate the file with MD5sums for the files I have and see if that works.
OK. My car required the USB drive, but I finally got the update to take. A few notes:
  • The MD5 file above is necessary. The first step in the update is verifying the files.
  • The values provided by skipgen worked.
  • The USB drive must be formatted FAT. The first one I tried was formatted XFAT, and kept throwing the "USB device not supported" error.
  • The contents of the 2015_16_Genesis_9_2_in_touch_USA folder should be placed at the root of the SD card. None of the parent folders should be included.
Thank you everyone for your help.
Okay, I'm back to trying to update my nav and I've run into the USB issue. I downloaded the update from MyHyundai.com today and saved the files to a formatted USB drive.
The screen on the software update says to plug in the "SD card" before going to the settings menu and selecting Update.
I've searched through the user manual and the separate audio system quick reference book, but there's no clue as to where the USB thumb drive goes. So, assuming the update has been saved correctly, how and where do you plug it into the vehicle?
Beats me. I saved the files to an SD card and put it back in. You can use the existing SD card in the car. The download program puts them on it for you if you choose to do so.
Yeah, but that requires plugging the SD card into my PC. I have no such slot, so I guess I'm going to have to get a USB- SD adapter. Back to Best Buy. :-)
And the next question is..where in car is the current SD car for the navigation? fuse box? glove compartment? Anybody got a diagram?
Right up front. Black cover on the lower part of the radio. Toughest part is to pop it off. Use a knife blade or very thin screwdriver.
After several trips to Office Depot to get a 32gb SD card, I downloaded the update from Hyundai's software updater and loaded the data. When the car started it 'Failed to Authenticate navigation" and wiped out the nav feature altogether. I had to put the old SD card back in. What causes this error message?
I don't have the Option 3 upgrade so I downloaded the2014 2016 Genesis (8 inch Touchscreen) update. Did I pick the wrong setting?
Oh, and when I tried to register my car on the nav app, it said the vehicle couldn't be registered, despite the fact that my VIN is listed on my sign-in. Is the car ineligible for a nav map update?
Can I assume you have the 8" screen?
I have no idea why it would not be registered with your VIN.
Did you use the program to write to the SD card? If not, do it again and let the program load the card as you may have an an error.
If none of that helps, perhaps you can call for some assistance as it is beyond me.
I know I have the 8" screen. When I opted for the 9 inch in the nav updater, it superimposed an image of the secondary controller, which my car doesn't have. I suppose I can try to re-save the data to the SD card, but, at this point, I feel like I've wasted an entire day and I don't feel like pouring more hours into it. I may call Hyundai instead and see what they say.
Thanks for all your help.
You're an excellent brand ambassador.
  • Like
Reactions: EdP
So I finally made some progress on this by contacting the folks at the MyHyundai site. I couldn't register the vehicle because I bought it pre-owned and they still had it registered to the original owner. I sent them the bill of sale and some other info and it's been updated. That means I can now opt for Bluelink services. :)
I ordered the nav map update & Apple Car Play upgrade from the Hyundai Auto Ever site. $25 plus S & H.
The SD card arrives tomorrow. They said there's a 50/50 chance it may not work on my car (no details were given as to what the critical criterion is) so I'm cautiously optimistic.
Sorry to hear that...only because I received an email that Bluelink Services will end in December 2022.
At least that's what the email says.
Genesis will contine with blue link.
