rear marker plate light bulb replacement
piece
ok i have a 2010 genesis one of the rear maker plate light bulbs is out, how do you change it?tried the 2 phillip screws can't seem to get the light to drop out to change out the bad bulb,do i have to come from the trunk lid?any help is much appreciated.jim
I would look at the owner's manual first, and then www.hmaservice.com (no charge for registration).
It's a little tricky but it will drop down (use a small jeweler size screw driver to pry it down) and then you can unplug it and separate the clear and black housing to inset the bulb.
that's the problem dropping it out,straight down or i was able to tip it down but it gets stuck as it is wider in center.thanks again in advance jim
You really wont hurt it by forcing it a little. It will come out, but IK what you are saying. It drops a little then gets stuck. Wiggle and pull. It'll come out
yeah went at with a couple of picks in the screw hloes and kept the lid vertical so it would drop out easier.thanks to all for the help jim;)
