QuantumRift
Thanks for the tip. I've not been able to find it in any case (it's harder and harder to find, maybe 'cause of the specs - used to be readily available at AutoZone but not so much anymore), last time I used it was for my Isuzu pickup. And if given the choice, I'd still stick with the 0w or 5w-20 over a 30w oil. But since I change fairly frequently, I would not expect the German Castrol to be that detrimental (I generally switch off from one manufacturer or another in any case). Good to know, though.
Much appreciated!
Much appreciated!
You probably aren't going to believe me (yes, I have read all the posts on Bob's the Oil Guy, etc), but Castrol 0W-30 European Formula does not meet Hyundai specs. That particular oil is designed for MB, BMW, VW, and a few others. Mobil 1 has a 0W-40 European Formula Oil (that also does not meet Hyundai specs) but Mobil 1 0W-30 AFE is not a European formula oil that does meet Hyundai specs.
If you want to use Castrol synthetic that does meet Hyundai specs, then make sure it does not say "European Formula." BTW, Castrol is now owned by BP.
Here is information from the Castrol Website:
Castrol EDGE with SYNTEC Power Technology 0W-30 meets the industry specification for a 30 weight oil, which is 2.9 minimum.
Castrol EDGE SPT 0W-30 is engineered to meet European specifications which require a higher minimum HTHS viscosity. The HTHS viscosity of this product is 3.5 cp
Follow-up info — Sep 21, 2012The one reason not to publish the HTHS viscosity is that this value can lead to consumer misinterpretation. A higher HTHS may be important in delivering performance and protection. However a lower HTHS viscosity can deliver fuel economy improvement. The important item is that the level of HTHS meets the vehicle manufacturers’ requirements for both fuel economy and protection. This is controlled through their recommendation of viscosity grade ( eg 5W-30 ) and specification ( eg API SN/ILSAC GF-5).
http://www.bobistheoilguy.com/castrol-edge-qa/
In addition to the above info from Castrol, European Forumula Oils are formulated with low sulfated ash, phosphorus and sulfur (SAPS) for environmental reasons in the EU.
