kozack
- Apr 21, 2020
- Location
- Sacramento
Any news on hardware needed to enable remote start? Thank you
Or you could simply press a key on a fob, and the car will start. There is simply no comparison in reliability and convenience.I love the blue link with Google assistant. Once linked together, you can just say “hey Google, ask blue link to start my genesis” it will then come back asking for your pin. Speak your pin and boom. Car will start. Of course all requirements still must be meant. Car locked and in view for command/signal aka not in garage with doors closed.
How inconvenient to have to be close enough to start it. I like being farther away, several floors up or out of line of sight so the car is actually warm when I get there. Also when I am father away I like getting a confirmation that it has act started. That’s convenience for me.Or you could simply press a key on a fob, and the car will start. There is simply no comparison in reliability and convenience.
When I had my remote starter installed they programmed by fobs to be able to start the car if I didn't feel like using the remotes. I have a 2015 Genesis awd. The code was lock and then the panic button within 3 secondsThis may be attributable to the fact that you had them install a remote starter. Regardless of whether you are using the fobs they gave you or the standard fob both of them may be triggering the remote start that was installed, which would explain why it does not work for anyone else who has replied to this thread.
what brand remote starter did you use? With the news of the shutdown of BlueLink, it will likely be popular...When I had my remote starter installed they programmed by fobs to be able to start the car if I didn't feel like using the remotes. I have a 2015 Genesis awd. The code was lock and then the panic button within 3 seconds
Didnt know this was possible with remote, I will try this on my 2015 3.8.I don’t have a remote start on my Genesis but the sequence worked for me!
did it work on the 2015 ?Does th
whats the name ?My remote start on my OEM fob is LOCK,LOCK,LOCK
2015 w/tech
No, didn't work for medid it work on the 2015 ?
