Maybe it would be useful for to explain the exact time-line of events. It now sounds like you had no symptoms or problems, and took it in (or they picked it up) for an oil change and dealer told you engine is damaged because not enough oil in crankcase?
Sounds to me like they drained the oil, forgot to refill (happens at many dealers based on automotive forums I read) and then they drive the car or run the engine for some reason, and ruin the engine, and then they blame the manufacturer (they probably put some oil back in crankcase after they realized the engine was ruined so they would have a plausible story about not enough oil from the factory).
Depends on how low is low. If it low enough to quickly damage the engine, then in most cars the oil pressure light would come on, and the owner would have noticed some other symptoms. But you are correct that 2 quarts down would not likely cause oil pressure light to come on (one quart down is not really a problem for the engine).Oil light is for pressure, NOT adequate quantity. Allow oil condition could yield adequate pressure, but starve a bearing at startup.
I know where this is going an oil sensor would be nice but only if its in addition to the dip stick. Always check your oil. Dealers will tell you burning a quart every 1k is normal. Whatever the case i always check oil.
Ppp
It has been a very long time since any car I have owned has used a quart of oil in-between oil changes, much less every 1000 miles. Using that much oil is not normal anymore, although I don't have any experience with Ford, GM, or Chrysler.I know where this is going an oil sensor would be nice but only if its in addition to the dip stick. Always check your oil. Dealers will tell you burning a quart every 1k is normal. Whatever the case i always check oil.
Ppp
Is it true that many MB must have oil sucked out from the top of engine bay because there is no oil drain valve at the bottom?Except some cars don't have a dip stick and the owner has to trust the computer system to show the oil level, which is what I have to do with my Mercedes. The Mercedes also will message in the instrument cluster if it needs a quart of oil.
As with the original post, we are totally confused as to what is happening. Did they agree to replace your entire car with a brand new one or not? Obviously, even if they replace your entire car with a new one, they will replace the engine on the old one, but that is not what we (and you) want to know.Update: Contacted by the Regional Service Manager that my request has been sent up to the "chain". They are moving forward with replacing my engine and that they will need me to use my car as the "loaner" when it is fixed. States that the process could take up to a month to resolve.
Received a call from the Service Manager where my car is being worked on. Very apologetic and understands why I am requesting a new car. Stated that my car would be ready early next week.
Need to say that everyone I have spoken with at Hyundai is very professional and they seem to want a quick resolution to this issue.
Stay tuned.........
They have not agreed on anything as of yet.
They have started to replace the engine on my car. When that is complete, they want me to return my loaner and then drive my car, (with the new engine), until the issue of the buy back is resolved.
They are stating that the repairs on my car will be complete by the end of next week.
I have already contacted an attorney and am taking very detailed notes.
