rickcinyyc
- Mar 18, 2022
- Location
- Calgary, Alberta
- Genesis Model Year
- 2023
- Genesis GV60
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Both of my front center console USB C sockets have failed.
Thanks - struggling to get a service appointment at the moment. Interesting to know that someone else has had the same problem. I can’t get the left hand socket to work, even if I hold the plug in tightly by hand to test it. Not worried about the cost as it will be a warranty item, but I am concerned that the part won’t be available!Yep we also have issue with he one on left for Android auto. We too have a MA1 module for wireless connectivity and to fix it at least temporarily we wrapped the emd in electrical type to make connection snug and stable. It doesn't click in but it is functional at least. The port moduel which also has the charge only port is only $135 so not end or the world. Had it looked at when they fixed the seat heatter/cooling button but tech said his cable worked fine and blamed the cable. Pretty sure it's not all 4 cables I tried. I'll have them revisit the issue next time
I realized from the first time I plugged something into these ports that they weren't very robust (understatement). I have been very careful every time I plug in or remove a drive or cable. I assume that mine will fail, and without redundancy, if the left one fails... no Android Auto (which should have been wireless), no music, no manual updates, etc. Does not inspire confidence.Thanks - struggling to get a service appointment at the moment. Interesting to know that someone else has had the same problem. I can’t get the left hand socket to work, even if I hold the plug in tightly by hand to test it. Not worried about the cost as it will be a warranty item, but I am concerned that the part won’t be available!
Add me to the list of dead 12-volt victims.
Friday it was totally dead. Car was dark & cold and wouldn't do anything.
Pulled up the access panel, attached the NOCO jump pack and it revived the car immediately.
I charged the battery up by leaving the car in utility mode for an hour. I've been checking the battery voltage over the last 18-20 hours and it has been falling. Started above 13 VDC and is at 11.14 now. Car is still "alive" at this voltage, but it seems really low.
I finally decided to give up checking the voltage and closed the hood. As soon as I did, the amber light came on to indicate charging.
So, I learned that the system won't charge if the hood is open.
Or you can locate and activate the micro switch triggering "hood open" message, which will allow you to trickle charge with hood open.I tried to drip charge once, what I noticed that when hood is open, there is a continuous reminder on the dashboard, with animation, that "hood is open". I think screen did go dark but whenever I opened the door, it came right back on. So, it simply means when drip charging with hood open, there is a continuous use of energy to keep dash on. What I can't tell if charging rate is faster than the consumption.
When I did remove the charger, orange light came on. So, safe to assume that car must have felt like battery has been drained, needs charging.
I'll try to see if I can run wire safely to charge and close the hood. I'm sure it should be doable.
I have when setting for a charger (for the heat pump) while driving - was a bad signal area and a few minutes later it worked no problem.View attachment 52949
Has anyone else had this issue with the on-board nav? I can tap the "On-board Routing" option and it does provide a route.
My NOCO trickle charger's cable fits in between the gap of the clam shell hood and headlight fenderI tried to drip charge once, what I noticed that when hood is open, there is a continuous reminder on the dashboard, with animation, that "hood is open". I think screen did go dark but whenever I opened the door, it came right back on. So, it simply means when drip charging with hood open, there is a continuous use of energy to keep dash on. What I can't tell if charging rate is faster than the consumption.
You beat me to it. I tried that just this afternoon today. Worked like charm. I ran through right headlight thoughMy NOCO trickle charger's cable fits in between the gap of the clam shell hood and headlight fender
I don't follow. Are you saying there is a switch that I can use to turn it off? If it's on off button then I can try but if it requires plugging and unplugging wire harness then I'd rather not. I was able to run wire under the hood fine, took extra 10 second, next time, it will be less than 5 as I know where to run. That worked perfect.Or you can locate and activate the micro switch triggering "hood open" message, which will allow you to trickle charge with hood open.
I have been using the NOCO tender/charger for months and charging with the hood open. While I'm charging the "Orange Light" on the dash will not come, which is great. Once the NOCO charger's green light comes on, I remove the charger and hook up a volt meter to the battery and it always shows +13 volts.I don't follow. Are you saying there is a switch that I can use to turn it off? If it's on off button then I can try but if it requires plugging and unplugging wire harness then I'd rather not. I was able to run wire under the hood fine, took extra 10 second, next time, it will be less than 5 as I know where to run. That worked perfect.
He's suggesting that you disable/bypass the hood open sensor (switch) while you have the hood open to charge the battery.I don't follow. Are you saying there is a switch that I can use to turn it off? If it's on off button then I can try but if it requires plugging and unplugging wire harness then I'd rather not. I was able to run wire under the hood fine, took extra 10 second, next time, it will be less than 5 as I know where to run. That worked perfect.
Exactly, like you would do in a washing mashine :-) locate it and keep pushed in while chargingHe's suggesting that you disable/bypass the hood open sensor (switch) while you have the hood open to charge the battery.
I'd love to see the picture to locate it. Most likely I'm not gonna do it but never hurt to know.Exactly, like you would do in a washing mashine :-) locate it and keep pushed in while charging
"Orange Light" didn't come on while charging with open hood. It came on once I removed the charger and closed the car.I have been using the NOCO tender/charger for months and charging with the hood open. While I'm charging the "Orange Light" on the dash will not come, which is great. Once the NOCO charger's green light comes on, I remove the charger and hook up a volt meter to the battery and it always shows +13 volts.
Yes, charging is greater than any consumption. When I charge the battery each month, I would hook up the charger in the morning and just leave it charging during the day until the green light comes on. The charging time normally takes at least 7 to 8 hours. I also think the charging time depends on which charger you have i.e. how many amps. I have the NOCO 2amp. NOCO makes a 1amp, 2amp, 5amp 10amp, 25amp, 50amp etc."Orange Light" didn't come on while charging with open hood. It came on once I removed the charger and closed the car.
I kept it plugged for good 3hrs or so, it didn't turn green. With wire hack under the hood, it was fully charged in 3hrs, orange light didn't come on.
Since you kept it connected to till full charge so I've to assume charging speed was better than consumption, it would just take longer.
I think with some of the members on the forum and from what we have seen on YouTube with the Ioniq 5 12V issues, there is a concern of a dead 12v battery. For example, if I externally charge the battery at the beginning of the month to +13v and then during the month the Orange Light would come on to charge the battery. However by the end of the month my battery voltage is down to 12.2v. Someone on the forum the other day mentioned his car was in storage or unused for 3 months and the 12v battery was dead. I assume that during that time the Orange Light was coming on to charge the battery, but it appears after a period of time it was not able to maintain enough of a charge of the 12v battery to start the car.For those regularly charging their GV60's 12V battery with an external charger, what is the concern you're looking to address?
Isn't observation of the orange light enough to assure you that the battery voltage is being maintained? Have you had some recurring issue that has lead you to believe the battery is not being properly charged?
