JasTheAce
hopefully with more robust capabilities in 4.3, samsung won't modify the bluetooth stack as much and it should solve some of the issues.
You don't have the Bluetooth streaming function so the only way will be the old fashioned audio cable approach.
I received the update on my S4 this morning. My 2009 Genesis Sedan with Tech package still disconnects the call...and reconnects. The update said that they fixed issues with the Ford Sync bluetooth...I was hoping our issue would be fixed...and just not stated.
I am curious about other's experience.
Bob
I have a 2010 Genesis Premium Plus. I had problems with the Nav Unit about a month ago and the dealer ordered a brand new unit direct from the factory. It has the latest and greatest map updates and I’m pretty sure the latest firmware. I’ve had a Galaxy S2 for the last two years and never had a problem, other than the phone connecting to the car when the car was turned off and not running, mentioned in other threads.
I received my new S4 today and it will not even pair. The phone finds the Genesis during the scan but then displays an error message “ Unable to communicate with Genesis” and the pairing stops. The phone had no problem working with my Motorola headset. Since it never paired, the Bluetooth Auto program is no help. Survived the day with the Motorola, but it is no substitute for the car Bluetooth.
Any help would be appreciated.
I have the same issue on S4 that I got today. Phone says it is up to date. It seems strange that some do not pair at all, some pair but have dropped calls and some have no problem. Any techs out there with an idea?
What version of the S4 are you guys getting? My ATT S4 works perfectly. The carriers each tweak the phones differently. I wonder if the S4 works on ATT but not the others?
I think it would be beneficial to list the following:
Genesis Year/Package (Base/Premium/Tech)/SW Version
Phone Model/Carrier/SW Version (from about phone, same menu to check for updates)
Talking to Verizon and they are noting the issue. It would obviously help if other Verizon users with the problem also advised them as that would likely move the issue forward. Maybe you could e-mail the assistant that I spoke with--- john.colebrook@verizonwireless.com?
I just emailed him about my issue as well.
