This idea of "zeroing out the up and down settings" sounded pretty logical to me and I gave it a try. I now have full movement where I have not had with the steering
wheel for months. Here is what I did.
I had lost steering
wheel movement months ago such that the top of the
wheel would block the top of the speedo and tach dials as well as the green headlights indicator. I had just learned to live with it although it always bugged me a bit for a new car ( my dealer looked at it at last oil change and said that was just the way it was). I have kept the steering
wheel exit switched on but do not have the seat exit assist on.
After reading the post I gave this "zeroing out" a try. With the car not running, I retracted the steering
wheel all the way down, then all the way in. Lo and behold after I pushed the steering
wheel adjustment switch up the
wheel went all the way up, well higher than before - now easily clearing the dash cluster fully!
After that, I immediately turned off the steering
wheel easy exit in the nav system. I can live with out the moving steering
wheel if it now stays where it should be. I don't know if this is what is referred to as "actuating " the steering
wheel for a temporary fix but it worked when nothing else did. I now have the steering
wheel back where it should be. Thanks for the great suggestion!
