Lead Head
- Nov 1, 2018
- Genesis G80 Sport
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
To the OP, when you went with the recommended plugs over the stock, we're the gapped for you, or was it not needed?I'm a pretty big amateur when it comes to these types of modifications, I appreciate any input you can share!
The Denso plugs can be used right out of the package. They don't need to be gapped...
Thank you! Apparently I'm out of the loop. I will update my post...Actually, they need to be regapped to .022 by Terry's recommendation. My indy did that before changing them.
Are you referring to this?Thanks to the both of you for replying ! I saw that there is a tool they also sell for gapping the plugs. Is that something that's difficult to do solo? I live in city where I'm not sure how reliable tuner shops are, so I try to do stuff where I can, or until the complimentary maintenance of the G80 Sport falls off xD
I'm sure he meant their tool KIA Stinger Denso 5346 Spark Plugs - BurgerTuning.com
@Lead Head ....if by any chance you live in Chicagoland, I'd recommend the shop for you.
Start calling any auto shops in your area and ask, it isn't rocket science, every mechanic should be able to do it under 2 hours, that includes regapping and changing the plugs.
I noticed you updated your previous post... so, installing the tune is pretty straight forward job. I didn't do it myself as my car was in my friend's body shop, so he even installed it for me, he did this so "professionally" almost invisible, to the point I had to ask him where those two plugs are connected, LOL
I'd say, it would take me less than 30 min.
No other modes, just the tune. With enormous amount of torque (~515tq) cars pulls so easily from any rolling speed 60-80mph, so much fun to drive it now.
How fortunate! Sounds like a good friend and a good mechanic to make it near invisible lol
Man reading you write about your excitement has got me all riled up to go after it now!
I saw the JB4 was one of only two so far featured on this forum, the other being the GTS brand. Is one been around longer than the other? Don't see much performance difference, but JB4 looks somewhat more simple to install..
A gap that is too close will not deliver the proper amount of spark to satisfactorily cause the air fuel mixture to burn cleanly. While a gap that is too wide may not allow the ignition system to fire the plug at all. Spark plugs that are not gapped properly will cause the engine to either skip firing, or ignite too soon in the compression stroke. 3.3L Turbo Stinger & G70 spark plugs are misfire prone.
Plus, heat range for the plugs is also important. Hotter combustion especially in the 3.3T requires a higher heat range plug as is utilized with the JB4 tuner. Denso 5346 are a higher heat range insulator used in most tuners.
Omg I love what I’m seeing!!! Btw that’s an incredibly beautiful colourOk, finally..... here are some numbers, car is stock, except the spark plugs. Recommended by Terry, I changed them to Denso 5346 and the car runs on 93 octane.
1st. pull was without the tune, so it was bone stock
2nd. pull - Map1
3rd. pull - Map2
All 3 pulls were in "Sport Mode" ....the car pulls like crazy now, a ~100tq more means something! lol
View attachment 15677View attachment 15679
But those dyno numbers are impressive. Its a Hyundai product after all and its producing that much HP and torque. I like a lot. I have to consider this. Is the JB4 tune hidden to the mechanics or not? I mean does it have a revert back to normal mode and stealth in that they cannot detect it?
I didn't installed my JB4 myself in my G80 sport, my friend did all for me, but as far as I know and I see, there are only two connectors to unplug.
Look at the pictures....you can barely see the JB4 box hidden behind the fuse box and those wires looks like OEM installed. I bet you wouldn't see them if I didn't marked them, lol
Yep, you can take it off within 5 min.
No, it's not detectable by the dealer, if you remove the unit before your services. When you do, it just reverts back to the original ECU and Tune. This is not a ECU Flash tune. ECU Flash tunes show up on the ECU flash counter. A piggy back tuner modifies the signal after the ECU and does not effect the original ECU OEM Factory Tune.
Your safe, don't be concerned.
