Does anyone have any idea where the access to the engine oil drain is located on the 2015 Genesis?
The underside of the engine seems to be completely enclosed by a large aerodynamic shroud that doesn't seem to have any access panel for changing the oil. The drain on my 2012 Gensis was easily accessed through an opening in the engine shield covering the oil pan.
Another point of interest on the 2015 - the oil filter is in a new location and is apparently accessed from above, without need to drop the bottom shield. However, some sort of small container is needed to catch the oil when the filter housing if removed. Filter size also appears to be all new - smaller then previous model.
