Roll call: who has the most mileage on the OD? What is your mileage?
2009 Genesis purchased Jan, 2014 w/ 89k km(55k miles). As of today, it's at 147k km (91k miles)
Cool.. You are racking up the annual miles greater compared to previous owner.
2013 RSpec sedan. Purchased 03/2013.
Mileage 5,976 Guess I win the award for lowest mileage.
Now at 20,###. Guess I'll hit 10 yrs first on my 10yr/100k extended warranty.
Put over 220,000 on our 2011 4.6 with tech. Only used OEM filters and Valvoline synthetic oil changed every 5000 miles. Car never used oil. Traded in for a new 2017 Toyota Highlander Limited Platinum.
2013 3.8 87.5k
Bought jan 10 2017 with 66.7k
I'm the second owner. Petty sure the original owner was an older gentlemen who commuted to San Francisco so basically all freeway
I have a 2010 4.6L with 158,000 but.... after 150,000 it’s burning almost quart of oil for 1000 miles wtf ???
2011 4.6 with 130k. Try cleaning your pcv valve, I was burning about a quart every 500 miles. Lucky for me, I’m getting better performance, better mpg, and zero oil burning for thousands of miles since cleaning. I would start there before assuming the pistons need new rings. I thought I needed a rebuild until I took 15 minutes to complete this easy service. also, put some 91 octane in it to clean those valves! Your engine is port injected! More importantly, research the forums better! This forum is a treasure trove of genesis Knowledge!
I am in the Ford Expedition forum. Someone did a roll call for how much mileage. A few were over 400k, several more in 300k range, and bunches in the high 100k or in the 200k range. Was great to read some of the stories and info. I bet there are some high 100k Genny floating around. And others with high mileage compared to the age. Let's hear about all mileage..
101156, 2012 5.0
I got 193k on my 2009 4.6, it's starting to show it's age in some areas but everything still works like it should
1872620190321_205026.webpgenesis power still running strong only mod is bc racing coilovers
I’ll sign in here with about 41,000 on the clock.
