the power is in your hands...don't have the tires replaced or the ECU reprogrammed...seems pretty simple to me.![]()
Maybe it seems pretty simple to you because you have no understanding if the problem. The tires are DEFECTIVE and have serious flat spot issues. As a result, they should be replaced with EQUAL tires, but cheaper lower performing tires, that require a change to the vehicles programming.
If the engine in your car had to be replaced, would you be ok if they swapped it out for a 200HP V6? a 4 cylinder? I seriously doubt that.
