Not to be argumentative but your tire pressure gauge must be broken.
What are the effects of temperature change on my nitrogen filled tires?
The pressure in nitrogen filled tires will change when the temperature changes, just as it does with air filled tires, because nitrogen and oxygen respond to changes in ambient temperature in a similar manner. For example, when your vehicle is parked it will lose a similar amount of pressure for every 10 degree change in temperature, whether the tires are filled with nitrogen or air.
The calculations for this change are based on the Ideal Gas Law. A good rule of thumb is this: For every 10 F degree change in temperature, the pressure will change by 1.9%. If a tire is filled to 32 psi at a temperature of 75 F degrees and the temperature drops 10 degrees, the tire pressure will drop to 31.4 psi; a difference of .6 psi. If a 100 psi tire is filled at 75 F degrees and the temperature drops 10 degrees, the tire pressure will drop to 98.1 psi; a difference of .9 psi.
These fluctuations will occur as the temperature rises and falls no matter what the inflation gas. Fortunately, tire manufacturers are well aware of these conditions and design their tires and recommend their cold inflation pressure accordingly.
