Android Auto for Genesis?
I have the file saved n my laptop. I emailed it to one member but I have not heard that he tried the install yet. I will send it to anyone who would like to give it a shot.
Im suprised someone hasn't tried this yet. Send me the file, I may have to do it myself. I think its a long shot to work, if it did work why would hyundai delay it.
I have an Ultimate. I'd be more then willing to try it out as well.
Will this target only the Ultimate? I have a base v8; will that be a good test platform? If yes, pls send me the file too and i can try
Thanks
Chances are, the installer will check the loaded system version and then reject the update.
The installer will most likely need to be altered.
Also, there are quite a few options that the Genesis has that would be lost due to the update of a Sonata configured update.
That's my guess anyhow.
Thats kind of what I expect to see happen also. PM me with your email address and I will send you the file to whoever wants to give it a shot. If it will work it will only work for the 8" screen so no ultimate trim model.
If it is just installing the AA app then it shouldn't make any difference. However, if it is upgrading the audio/nav system then that might be the case.
Thanks
I would not try it on the Ultimate system (though I fully expect the update to be rejected regardless of system). The Ultimate system uses different hardware and OS than the standard system (which is identical to the Sonata).
Checked my mail again and nothing. Also checked the junk folder in case it went there.
Sending to both email accounts again now. They will be coming from my Lonnie.Huddleston @.......
If we can't get email to work, we are screwed with applying this update to our car. :D
I still never received the file at both of my email accounts I gave you. I really wanted to try it and see if it works for us.
send me the file, I'll be back in the country this weekend and i'll see what happens with my tech model
Just got home from work. I will blast it back out to everyone later tonight. I might try it from a couple different accounts so look for a subject line AA
I'm going to take a flyer and say that if you are interested in Android Auto, you probably have a Google Account. If you have a Google account, then you have easy access to Google Drive. I might recommend that whomever has the update upload the file to Google Drive and use the "Share" feature with the others. Don't even have to download Google Drive as the web client is quite robust and it gets past some of the limitations of email. Just a thought.
