GenX
I got into the Coupe's engine compartment a bit today.  Steve and Rich took a lot of pictures that Rich will be editing and posting up tomorrow.  LOTS of interesting things under the hood.
Fuel system is a returnless style but has a removable plug on the end that could possibly make it adaptable to a return style system with a boost compensating fuel pressure regulator.
The intake manifold is quite odd. It appears that there is a vacuum reservoir built into it.
The BOV is installed in the compressor housing (like an SRT-4) and is connected to the vac reservoir which allows the ECU to open it even under boost. When we had the car on the dyno Sunday, we found the boost limit at around 18.5 psi but it was not a hard cut like we normally see (when fuel injectors are shut off) but rather a soft cut like the BOV was being opened. Our engineering department took measurements for a CNC block off plate!!
The intake tube has a large restrictive metal muffler installed in the middle of it. If I remember correctly, it necks the inlet down to around 2" in that spot. The good thing is that it is easily replaced with a piece of tubing. I am not sure if you will see HP gains from deleting this on a stock car, but it will eventually be a restriction as mods progress. The intake also has a large capped off bung on it that looks as if it was designed for a recirculating BOV. I have already noticed oil in the intake tube. I have 200 miles on the car. A catch can for the PCV system will certainly be needed to prevent oil from coating the inside of the IC piping and intercooler.
The air filter box and ducting to it seem to be very nice pieces. Air enters the upper grill opening in the bumper and flows through slots on the radiator block off plate to the inlet of the snorkel for the air box. We will do some testing, but I think that the factory setup should be just fine for most applications.
The compressor wheel on the turbo is actually bigger than I had anticipated. It will be interesting to see what the turbine side looks like. It will also be interesting to see what kind of HP we can get out of the factory turbo before we upgrade it.
Intercooler piping is thick wall aluminum. ID is approximately 1 3/4" on the hot side pipe I measured. An upgrade will be needed here for sure.
I am sure there are other things I am forgetting but I will have to review the pictures tomorrow.
	 There were some gains, but not much at factory boost levels.  I am pretty sure that once we address all the corks in the system, we will get a better idea of what each part does for the car.
