The AMS Genesis coupe is HERE!!! Let the modding BEGIN!!!
Alright, I am going to spill the beans on today's dyno pulls, but you will have to wait till Monday for actual dyno charts. Chris will be posting them up as soon as he has time to go through them.
Our baseline dyno numbers on 93 octane fuel are 192 WHP and 219 lbs Tq (SAE corrected) with the 100% bone stock car, stock boost control and no tuning at all.
Today with JUST BOLT ON AMS prototype parts, we put down 212 WHP and 220 lbs Tq (SAE corrected) still on stock boost control and no tuning at all.
Well, the 20 WHP gain is quite nice but only 1 more lb of TQ??? What the hell am I so excited about (you might be asking)??? Well let me tell you. These are just PEAK numbers. To fully appreciate the gains you must see the dyno charts. With the stock turbo, you make peak Tq very low in the RPM range due to the boost rapidly falling off after hitting its peak. The gains we were seeing with the bolt on parts are at a higher RPM range. The gains in HP and Tq start at 3500 rpms and HP gains are consistently 20 WHP from 4000 rpms to red line. The Tq curve has flattened out quite a bit. If boost did not drop so drastically, I am sure we would see a VE similar to the Evo X motor where the TQ just stays flat and HP keeps climbing.
After the disappointment in the cat back and secondary cat delete dyno testing, I was confident that there was still a cork (or three) in the system and obviously I addressed those today. The difference in today's dyno testing was the prototype AMS down pipe, prototype AMS intercooler and prototype AMS intercooler piping. One (or all three) of these items freed up the HP I just knew was there.
Now before you say "well, that was ONLY 20 WHP", let me explain something else. As I have mentioned before, I believe that the Gen Coupe was not showing gains because we are not leaning on the car that hard. In stock form, this car is only rated at 210 crank HP. This is only 2/3ds of the Evo X rated crank HP. I have always had the opinion that if we were starting with 300 HP, the gains from bolt on parts would be more. Well........... just to prove this, I TURNED THE BOOST UP with the AMS bolt on parts!!! Here is the proof.
With the 100% bone stock car and no tuning at all, we were able to run a peak of 18 psi dropping to 12 psi at red line (before hitting boost cut). We made 204 WHP and 249 Lbs Tq. (SAE Corrected)
With the AMS prototype bolt on parts and no tuning at all, we also were able to run the exact same peak of 18 psi dropping to 12 psi by red line. We made an incredible 236 WHP and 237 Lbs Tq. Again, peak Tq does not show the full picture as it happens well before the gains from the AMS bolt on parts.
That is 32 WHP gains from just the AMS bolt on parts at this boost level!!!! This proves that the stock components are choking the motor and the more you turn the boost up, the more the stock components are going to rob power. Now imagine the gains you would get from the bolt on parts at 300 WHP!!!
I hope you can all see why I am excited now. If not, the dyno charts Chris will post should explain everything.
P.S. Uncorrected (ACTUAL) numbers today were 241 WHP and 243 Lbs Tq!!!
AMS ... I hate you. I told myself not to mod the car then you come up here and start throwing big numbers and amazing products at me. Ugh...
One more pic to wet your appetite....
I will have more details about this on Monday!!!
Cool manifold. I assume that by blocking half of the ports, we're trying to increase velocity? :D
LOL... You should be careful, somebody might believe that. :D
While I had the turbo and exhaust manifold off the car to remove a broken stud, Drew took the opportunity to mock up turbo placement for our upcoming turbo kit.
GT28RS? Or something you guys are coming up with just for us? :)
SO with you guys behind this car, I'm getting very tempted to trade in my Tiburon and treat myself to something RWD again :D Keep us updated, I'm really excited to see what you come up with next.
Im thinking of getting one of these cars but I think I should wait till ams finds out the week links. You guys are awsome. I will b watching this thread very often. Cant wait to here about the internals of the motor, and the drivetrain?!
I am waiting for AMS to break the 300whp mark with mods then im in! Thank you AMS for doing all the hard work for me! I will def be buying from you when you get this going!
Here are the charts from Ivan's last posts. All of these tests are done with NO tuning so far.
the lowest chart is the baseline
the middle chart is the bolt-ons with stock boost
the highest chart is the bolt-ons plus about 18psi of boost and no tuning!
I know you guys are working after hours, but.... MOAR!!!! :D:D:D
Wow, you guys have got a lot accomplished in a short period of time. Good job!
And, settle down Britt!
Keith... when I pick mine up, you guys need to use it for anything? I'm getting a 2.0T Track.
did AMS just quit on the Genesis Coupe or are there updates in another thread !?!?
carlos nice
Hey Aaron...we got our 2.0T a few weeks back. I posted dyno graphs in the other thread (don't want to thread-jack). Good power gains to be had. So far, just the CMD on it. :) Check it out.
ams does not make their own turbos.... shaking head.
now that you oncorked it. TURN UP THE BOOST! i want to know how much psi this little turbo can pull. How much before internals need to be replaced? how much twist can the tranny handle?! ecu's probably going to be a pain. can you tune with a plug in play? safc? is this car's fuel system designed for e-85? pics of the intake manifold?
i am wondering how your going to re-route the intercooler plumbing and where are you going to mount the intercooler? i don't own this car but i feel the itch... haha can you tell
