Nikgen
- Jul 8, 2014
The rear camera resolution is fine. More than fine for a car which costs less than half of similar cars with the same or worse rear view camera. It's function is to aid backing up and avoiding objects - the resolution and two angle options perform that very well. No reason to see if a coin on the ground is a dime or nickel, so its function over cost done well.
As I clearly said: it works fine - but it could certainly be better and the refresh rate is slow - when cars pass by behind you and you get the cross traffic alert, the car's movement is quite jerky/stuttery.
