Pickle
Crunchy and Sour
- Jun 3, 2019
- Location
- Canada
- Genesis G70
Installed my DIY intakes last night. I used the Spectre heat shields and used some DEI Reflect-a-gold on the back side of them to help reflect heat. Drive to work this morning outside temp was 70F. Intake temps climbed up to 100F doing about 55mph (sometimes dropping down to 98F). On a slower road before parking, temps climbed to 113F. I'd argue IAT temps seem about the same as the K&N panel filters. You can hear the turbo's spool now at lower speeds, and you can hear the OEM BOV a bit more now (which sounds kinda like a bullfrog). I did some trimming of the heat shields to reduce concerns of the sharper bottoms edges cutting into anything, then added car door edge guards. I'm not a huge fan of how the heat shield pushes against the hoses on the drivers side, but there isn't much a person can do about it.
I did some looking up by the grill area, etc. I honestly can't figure out where the outside air is feeding the OEM airbox? I never understand why the OEM's don't give the airbox a direct path to outside air.
I'd be curious to what your seeing for IAT temps Pickle with your setup....
Did some measurements today. I got similar results as you. Ambient temp of about 70F. IAT values:
At Startup: 74F
Cruising: 85-95F
WOT: 86F
Parked: 105F
So, the snorkels are working because I'm definately getting more cool outside air than engine bay air. Simply, the faster I go, the cooler the IAT is. Sitting still, with no airflow spikes the temps.
Generally, my IAT is running around +20F above ambient while driving, speed dependent with the DIY intakes.
