j_fields1357
- Dec 10, 2017
- Location
- virginia
Has anyone ever thought of deleting or gutting the primary cats?
Are your pipes still available?
Sorry if I did not reply before and the late response. Yes they are still available.Are your pipes still available?
I've had my intake and magnaflow catback for over a year, someone posted dyno results on youtube showing a 10-15 hp increase, I can say that after installing the test pipes a couple weeks ago, I do notice even more improvement in midrange torque and a definite better throttle response and my mpg is even better with the less restriction.You will get a little more sound (not a whole lot). I'd be amazed if the increase in power/torque is measured to be any more than variations from pull to pull on a dyno. Likely less than 5 ft. lbs. torque/HP. This is an educated guess, not based on testing this car.
I wouldn't recommend 'gutting' the 2ndary cats. It's a PIA & that sh*t inside is lethal. You have to make sure every bit of it is removed. I replaced my 2ndary cats w/test pipes... and WOW, what a difference!! Better throttle response, better mid-range torque. Best $140 I've sent so far.
Do you still have test pipes?If someone sends me a message, I have a set of pipes available. They came off my 2011, don't fit on the 2015 I now drive.
What about having a shop cut the pipe where those secondary cats begin, weld a flange to the cat and the existing pipe so they can be bolted back on together (if you want to go back to using the cats for emissions or if its just too noisy), and then having them use a short test pipe with a flange on both ends?G-896285 - no - my test pipes were sold some time ago.
kaigoss69 - test pipes for this generation (I don't have my 1st gen anymore, now have the 2nd gen) are likely not going to be made (IMHO). The 1st gen cars had the secondary Cats bolted in on both sides, so a replacement piece of tubing with flanges of fixed length was easy to make. Our 2nd gen cars now have the cat welded on the inlet side (I think the outlet side is flanged - can't remember). The only way to do a test pipe would be to sell with the flange on one end, and an inlet pipe of geometry and diameter that it could be clamped in place (a longer segment of slightly larger diameter). The downside would be that if you ever would wish to put the original cats back in, you'd need a tube that could go over both sides of the joint with 2 clamps, or re-weld the cat inlet tubing back in place.
