I'm at a loss...
Todd, that speckled stuff on the brass throttle butterfly isn't overspray. It's condensed hydrocarbons and 'tars' , byproducts of the combustion process. The butterfly is always 'cool' when the engine is running and guck condenses out of the airstream. It builds to a point where it begins to affect idle quality. At that point we do a "throttle body cleaning" using bottle brushes and throttle body cleaner to make everything nice and shiny again.
You don't have near enough guck (technical term) to worry about yet.
When you start the engine (WITH THE COOLING SYSTEM CAP ON) let it run until your temp indicator is in the normal range, maybe let the fan come on one time. Then shut the engine off and refill the radiator and coolant bottle AFTER the engine cools down. You'll then be all set, no air.
Always squeeze your hoses to ensure they are soft before opening the cooling system. You don't want "Old Faithful" in your garage!
Next I installed the passenger side strut tower brace, make sure you torque it down properly (20lb-ft)...
And then the front bumper/radiator top cover piece by putting in all the plastic rivets....
NOW - time to get ready to refill the coolant. First thing I needed to do was find the coolant bleeder hose. The FSM states that it's on the front, top of the engine block, underneath the wiring harness and under some insulation foam. I had to remove some of the wiring harness from the top of the block to make enough room to move it out of the way, take a look..
First, unplug and unclip the top of the engine wiring harness from the passenger side bank, as seen here...
Next, unbolt the plastic harness stay/guide/bracket from the top of the block so you can move it out of the way...
Now you can lift the stay/guide/bracket up, and remove the foam insulation block to reveal the bleeder hose...
There it is in all its glory...
Pop that little guy off to get ready to refill...
Don't forget the rags!
Nice work! Seems like a strange place to put a coolant bleeder! 🙄
All modern reality series have a reveal at the end. I hope Todd's is that he's the technician at my local Genesis dealership.
I think, in the final episode, we'll discover that his G70 is a recovering heroin addict who relapsed twice before discovering, on Maury Povich, that he really is the father of her child. And, the G70 comes out as transgender and is now known as Ryleigh. Ryleigh is moving to California because she finally discovered her singing talent and aspires to compete on The Voice. But first, she has to reveal all of this to @Toddasaurus .
Hey, it's 2019. C'mon.
Nice, I didn't know that about the gunk in the throttle body... I just figured it was leftover bits of something from the assembly? This is good to know, probably something worth checking and cleaning every 10k miles or so.
I was planning on squeezing out as much air as I can tonight, then I'll start it up just like you said and get the air out the old fashioned way (again, like you said, let the coolant cycle through) then I'll let it cool off, and tomorrow I'll pop the bleeder hose again and top it off.
Hopefully I'll be driving this damn car tomorrow. Finally.
I better be driving...this waiting thing is getting old! JK!
My view? Best thing was when you had to wait for the turbo and spent a week away from the thing. (Yes, I know. You were re-reading the manual and checking parts, and it was in your dreams)
YOU (with out a doubt) are THE MAN!!!
I guess it's too late to remind you about checking how the throttle moves when in sport mode vs eco vs comfort, but I'm glad this is almost done! I'll just drive up to your house for my bi annual services from now on. Please and thanks! LOL
Still got to bleed out some more air, but......it's alive!
Fantastic work Todd. Now go drive it like you stole it and your worries will be gone.
BTW love the Retro Oregon plate (the front one is in the trunk right?😉)
I just found, and binge-read this thread. Amazing!
Sweet!!! But why is only one exhaust working? JK
Haha! You take that back!
Yupparoo! 2nd plate is in the trunk - even have the plate mount in there too. 😉
Right on man! Good for you!
You know more about the car now than most ;)
September 3, 2019 Post #45
At the dealership.now, and it really looks doable to get the turbo out. Infact, it looks like the manifold bolts are easier to get to than the downpipe studs were! It's got a fair bit of stuff in the way (ie intake piping, cold charge piping, oil and coolant lines), but once those are out I should be able to get the turbo out.
I'm gonna do this myself. Calling the tow company right now.
Well done Todd.
I have been waiting to resurrect this post.
