Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
- Feb 18, 2018
- Genesis G70
I genuinely appreciate the comments, thoughts, and ideas so far!
@NLJ and @mrcleeaan - nobody nearby to help for the time being, mostly because of my work schedule and no extended family nearby. I have a couple work buddies but so far their schedules have been out of sync with mine and have been unable to lend a hand. Even so, I appreciate the thought! Would love it if you guys were here helping me out! I could really use another set of hands.
@EdsNotHere - I was considering it while tossing and turning at night.. but, it may not be needed now because...
....I GOT ONE OF THE BOLTS ON!!!
This is VERY difficult. Here's what I did.
First, after mounting the turbo back on, I removed all the manifold nuts except one...
This last nut I kept on, but kept it at the end of the threads for more room to move the turbo....
I started out really loose, then went under the car to check the holes, then would nudge the turbo around, then come back up and tighten this nut again a little more, then go back underneath to check the holes.... I did this, again, and again, and again, until finally it looked right. Hand-threaded the bolt partially in, but the friction of the flange and everything not being perfectly flush, it gave me a little resistance, but not too much. Threaded in all the way by hand!
Now, I need to loosen it a tiny bit so I can re-align the gasket and the other bolt holes on the other side of the oil flange. Once those are lined up I'll just have to cross my fingers that I can get the bolt in there. I may have to trim the tip of the other bolt as well to help get the threads started like on this one.
For now, I'm breathing a HUGE, but temporary, sigh of relief.
