2017/2018 radio swap in 2016 ultimate?
Did a MOST reset now it’s all green.. going to wait a couple minutes and see if that does it!D7FB6C8B-6223-4397-8DD4-591781EB1BFA.webp
So MOST AMP is being detected but the iBox says it’s not being received. What do you guys think?
Did they disable the engineering Bluelink+Menu+RightSideTrack combo in the G80? I haven't had an Ultimate G80 to test it on.
Never worked in mine.
I believe Ibox is the telematics unit for Sirius data Connection for traffic and weather.
IBOX is only supposed to be present on the non-9.2" cars, never seen it show as present otherwise.
Still no normal sound?
You could theoretically take the optical cable going to the amp and send it into a TOSLink DSP module, the optical data is standard 7.1CH stuff.
No sound. Link on a recommended module?
Don't have one, never tried any of the options out there. There is a company making such a product but it doesn't specify Hyundai support. Whether that's because the connector doesn't fit or Hyundai uses a nonstandard command format, I don't know.
Damn. So close, yet so far....!
So on mine the selection is DH/PE.
The ibox is definitely present; as I said this is the telematics unit, which has discussed here quite a bit as it is the data connection for blueljnk and Sirius. Quite a few members have had to have it replaced if the bluelink account was dormant more that a year (people purchasing used for example).
Ibox, Amp etc all show not received until you choose the request option.
also in the diagnostics option I saw an option for a total unit reset.
Since you don’t know the status of the unit from the previous car I’m wondering if the reset wouldn’t be a good idea this way or reconnects to your bus and searches out the features of your car.
Sadly the options selected did not work..
Since I have the 3.8 with 14 speakers is that a potential issue? Since the 5.0 has 17 speakers?? Maybe this head unit is for the 5.0??
If you have 14 speakers then you don't actually have Lexicon. Lexicon is 17.
The head units are the same, hence the Lexicon setting. You may be sending 7.1 audio to a 5.1 amp.
Interesting.. will uncheck that setting later!
If you have the Jog wheel then it's 17 spkrs.
