Sebastian4k
- Sep 22, 2019
- Genesis G70
Never worked in mine.Did they disable the engineering Bluelink+Menu+RightSideTrack combo in the G80? I haven't had an Ultimate G80 to test it on.
I believe Ibox is the telematics unit for Sirius data Connection for traffic and weather.So MOST AMP is being detected but the iBox says it’s not being received. What do you guys think?
No sound. Link on a recommended module?IBOX is only supposed to be present on the non-9.2" cars, never seen it show as present otherwise.
Still no normal sound?
You could theoretically take the optical cable going to the amp and send it into a TOSLink DSP module, the optical data is standard 7.1CH stuff.
Hmm.. still no dice. Tried a bunch of options with no sound. debating if I should buy a newer amp and see if that does itDon't have one, never tried any of the options out there. There is a company making such a product but it doesn't specify Hyundai support. Whether that's because the connector doesn't fit or Hyundai uses a nonstandard command format, I don't know.
[/URL]
I’ll give it a shot... once I get off workThese are the setting in my 2018 sport
Good Luck!I’ll give it a shot... once I get off work
Good Luck!
Since I have the 3.8 with 14 speakers is that a potential issue? Since the 5.0 has 17 speakers?? Maybe this head unit is for the 5.0??
Interesting.. will uncheck that setting later!If you have 14 speakers then you don't actually have Lexicon. Lexicon is 17.
The head units are the same, hence the Lexicon setting. You may be sending 7.1 audio to a 5.1 amp.
